HTC Desire 826 Battery Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
Past 7 Days:
17
Past 30 Days:
70
All Time:
1,144
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
If you need to install a new battery in your HTC Desire 826, access it with this guide.
Tools
    1. HTC Desire 826 Battery Replacement, Battery: step 1, image 1 of 3 HTC Desire 826 Battery Replacement, Battery: step 1, image 2 of 3 HTC Desire 826 Battery Replacement, Battery: step 1, image 3 of 3
      • Find a seam in the back of the device.
      • Insert the plastic spudger into the seam and pry off the back panel.
      • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
      Ask FixBot
    2. HTC Desire 826 Battery Replacement: step 2, image 1 of 3 HTC Desire 826 Battery Replacement: step 2, image 2 of 3 HTC Desire 826 Battery Replacement: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
      • Remove the metal bracket with the tweezers.
      Ask FixBot
    3. HTC Desire 826 Battery Replacement: step 3, image 1 of 1
      • Disconnect the battery cable from the motherboard with the tweezers.
      Ask FixBot
    4. HTC Desire 826 Battery Replacement: step 4, image 1 of 2 HTC Desire 826 Battery Replacement: step 4, image 2 of 2
      • Lift the battery with a plastic spudger and remove it from the device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 70
All Time: 1,144
