HTC Desire 816 Camera Replacement
    1. HTC Desire 816 Camera Replacement, Battery: step 1, image 1 of 1
      • Pry open the back panel by inserting the plastic opening tool on the left of the camera. We find this spot the easiest to get the tool under the panel.
      Ask FixBot
    2. HTC Desire 816 Camera Replacement: step 2, image 1 of 1
      • Once you get an open spot, with a second plastic opening tool, slide down to the bottom of the phone to free the rest of side.
      Ask FixBot
    3. HTC Desire 816 Camera Replacement: step 3, image 1 of 1
      • There is adhesive between the battery and the back panel. Take a nylon spudger to cut through the adhesive.
      • Be sure to use the correct tool for the job. Metal spudgers can puncture an unprotected battery, potentially causing a fire.
      Ask FixBot
    4. HTC Desire 816 Camera Replacement: step 4, image 1 of 1
      • Once all way around the bottom, the panel should be broken free of the adhesive, and the rest of the panel should pop right off.
      Ask FixBot
    5. HTC Desire 816 Camera Replacement: step 5, image 1 of 1
      • Insert a nylon spudger at the bottom of the battery and lift up to remove the battery.
      Ask FixBot
    6. HTC Desire 816 Camera Replacement: step 6, image 1 of 1
      • There is adhesive on the other side of the battery as well, take the nylon spudger used to get off the panel and cut through.
      Ask FixBot
    7. HTC Desire 816 Camera Replacement: step 7, image 1 of 1
      • Carefully lift battery backside first to disconnect the white connector.
      Ask FixBot
    1. HTC Desire 816 Camera Replacement, Back Facing Camera: step 8, image 1 of 1
      • Take the T5 screwdriver head to take out these 4 screws
      Ask FixBot
    2. HTC Desire 816 Camera Replacement: step 9, image 1 of 1
      • Remove the black plastic casing with a plastic opening tool.
      Ask FixBot
    3. HTC Desire 816 Camera Replacement: step 10, image 1 of 1
      • Take the PH000 screwdriver head to take out the one screw that's holding down the green panel. (The screw is located on the left side of the panel)
      Ask FixBot
    4. HTC Desire 816 Camera Replacement: step 11, image 1 of 1
      Tool used on this step:
      Buy
      • With your pair of tweezers carefully unplug the black and red wire in order to remove the motherboard
      Ask FixBot
    5. HTC Desire 816 Camera Replacement: step 12, image 1 of 1
      • Once you have removed the wire, you can carefully lift up the motherboard
      Ask FixBot
    6. HTC Desire 816 Camera Replacement: step 13, image 1 of 1
      • Peel off the yellow film that’s attaching the camera to the motherboard
      Ask FixBot
    7. HTC Desire 816 Camera Replacement: step 14, image 1 of 1
      • Slowly lift up the white connector so that the camera’s cable may properly be detached.
      Ask FixBot
    8. HTC Desire 816 Camera Replacement: step 15, image 1 of 1
      • Carefully peel off the adhesive so that the camera can be disconnected from the mother board
      Ask FixBot
4 other people completed this guide.
Saleena Douangphachanh
618 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 44
All Time: 2,999
