HTC Desire 700 Dual Sim Rear Panel Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
26
Past 30 Days:
93
All Time:
1,864
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 8 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
The rear panel of the phone is responsible for keeping all of the device's hardware safe and secure. It is secured by eight 8.3 mm Torx head screws, and is accessible by first removing the back cover and battery. If the rear panel is damaged, it should be removed and replaced as a damaged panel can lead to damage of other internal hardware.
Tools
    1. HTC Desire 700 Dual Sim Rear Panel Replacement, Back Cover: step 1, image 1 of 1
      • Use the spudger to pry the back cover off.
      Ask FixBot
    2. HTC Desire 700 Dual Sim Rear Panel Replacement, Removing Battery: step 2, image 1 of 1
      • Use spudger tool to pry under the battery to lift it up and out.
      Ask FixBot
    1. HTC Desire 700 Dual Sim Rear Panel Replacement, Remove 8 Torx Screws: step 3, image 1 of 1
      • Remove eight 8.3mm T4 screws with the Torx screwdriver.
      Ask FixBot
    2. HTC Desire 700 Dual Sim Rear Panel Replacement, Prying Off Rear Panel: step 4, image 1 of 1
      • Pry the back panel of the screen using the plastic opener.
      • Work your way gently around the device, using picks as necessary to keep the back panel separated.
      • Use caution not to damage the device, as it takes force to remove the rear panel.
      Ask FixBot
Steven Pate
196 Reputation
7 Guides authored
USF Tampa, Team 9-3, Blackwell Fall 2014 Member of USF Tampa, Team 9-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S9G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 93
All Time: 1,864
