HTC Desire 530 Micro USB Port Replacement
    1. HTC Desire 530 Micro USB Port Replacement, Micro USB Port: step 1, image 1 of 1
      • Remove the four 1.2mm screws in each corner.
      • Use the suction cup and plastic opening tool to pry the screen from the body.
      Ask FixBot
    2. HTC Desire 530 Micro USB Port Replacement: step 2, image 1 of 1
      • Gently pry the battery up at these three spots, and disconnect the power cables attached.
      Ask FixBot
    3. HTC Desire 530 Micro USB Port Replacement: step 3, image 1 of 1
      • You can then fold the battery back like so, and that will give you access to the screw.
      Ask FixBot
    4. HTC Desire 530 Micro USB Port Replacement: step 4, image 1 of 1
      • Use the screwdriver to remove the 1.2 mm screw at the bottom of the phone.
      Ask FixBot
    5. HTC Desire 530 Micro USB Port Replacement: step 5, image 1 of 1
      • Once the screw and the black plastic backing are removed the daughterboard pulls right out.
      Ask FixBot
    6. HTC Desire 530 Micro USB Port Replacement: step 6, image 1 of 1
      • In order to fix the Micro USB Port, the entire daughterboard will need to be replaced because all connections are soldered in.
      Ask FixBot
Eric Blackstock
403 Reputation
2 Guides authored
UMASSD-PEAK-F18S3G2 Member of UMASSD-PEAK-F18S3G2
Community
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 940
