HTC Desire 510 Earpiece Replacement
Video Overview
    1. HTC Desire 510 Earpiece Replacement, BATTERY REMOVAL: step 1, image 1 of 3 HTC Desire 510 Earpiece Replacement, BATTERY REMOVAL: step 1, image 2 of 3 HTC Desire 510 Earpiece Replacement, BATTERY REMOVAL: step 1, image 3 of 3
      • Switch off the phone, remove the battery and any installed SIM and memory cards.
      • Remove 7x Torx T5 screws.
      Ask FixBot
    2. HTC Desire 510 Earpiece Replacement, REAR BEZEL REMOVAL: step 2, image 1 of 3 HTC Desire 510 Earpiece Replacement, REAR BEZEL REMOVAL: step 2, image 2 of 3 HTC Desire 510 Earpiece Replacement, REAR BEZEL REMOVAL: step 2, image 3 of 3
      • Use a plastic tool to remove the rear bezel.
      • The loudspeaker is on the inner side of the rear bezel.
      Ask FixBot
    1. HTC Desire 510 Earpiece Replacement, FLEX CABLES DISCONNECTING: step 3, image 1 of 3 HTC Desire 510 Earpiece Replacement, FLEX CABLES DISCONNECTING: step 3, image 2 of 3 HTC Desire 510 Earpiece Replacement, FLEX CABLES DISCONNECTING: step 3, image 3 of 3
      • Disconnect the touch screen flex cable.
      • Disconnect the light sensor flex cable.
      • Unstuck the vibra-motor from the middle frame.
      • Remove the coaxial antenna cable from the middle frame.
      • The LCD display flex cable is connected to the bottom side of the board.
      Ask FixBot
    2. HTC Desire 510 Earpiece Replacement, LOGIC BOARD REMOVAL: step 4, image 1 of 3 HTC Desire 510 Earpiece Replacement, LOGIC BOARD REMOVAL: step 4, image 2 of 3 HTC Desire 510 Earpiece Replacement, LOGIC BOARD REMOVAL: step 4, image 3 of 3
      • At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
      • Gently disconnect the LCD display flex cable.
      • Now remove the logic board.
      Ask FixBot
    1. HTC Desire 510 Earpiece Replacement, EARPIECE: step 5, image 1 of 1
      • The earpiece is in the upper part of the middle panel.
      Ask FixBot
4 other people completed this guide.
ZFix
197,480 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
334 Members
7,272 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 23
All Time: 1,881
