Up to 20% off select tools
HTC Amaze Motherboard Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
88
All Time:
1,074
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 - 15 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show the reader how to remove the motherboard of the HTC amaze by accessing the motherboard through the removal of the back panel of the phone.
    1. HTC Amaze Motherboard Replacement, Battery: step 1, image 1 of 2 HTC Amaze Motherboard Replacement, Battery: step 1, image 2 of 2
      • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
      Ask FixBot
    2. HTC Amaze Motherboard Replacement: step 2, image 1 of 1
      • Once you locate the battery, look for a notch below it.
      • Gently insert your fingernails into the notch.
      • Lift the battery out of its recess.
      Ask FixBot
    1. HTC Amaze Motherboard Replacement, HTC Amaze Back Panel Disassembly: step 3, image 1 of 3 HTC Amaze Motherboard Replacement, HTC Amaze Back Panel Disassembly: step 3, image 2 of 3 HTC Amaze Motherboard Replacement, HTC Amaze Back Panel Disassembly: step 3, image 3 of 3
      • Use the Torx T5 screwdriver to remove the 7 Torx Screws (3mm) attached to the back housing of the device.
      • One of the Screws may have a tape attached to it that says void. Removing this screw will void the devices warranty.
      Ask FixBot
    2. HTC Amaze Motherboard Replacement: step 4, image 1 of 3 HTC Amaze Motherboard Replacement: step 4, image 2 of 3 HTC Amaze Motherboard Replacement: step 4, image 3 of 3
      • Proceed to remove the back housing by using the spudger to gently unclip each clip holding the back housing in place and then lift the outer edges of the back housing
      • If you're having trouble opening the back try using the spudger to gently pry all around the panel before you attempt to remove it.
      Ask FixBot
    3. HTC Amaze Motherboard Replacement: step 5, image 1 of 2 HTC Amaze Motherboard Replacement: step 5, image 2 of 2
      • Now simply remove the back panel by gently pulling. This will make it easier to access the devices internal components.
      Ask FixBot
    1. HTC Amaze Motherboard Replacement, Motherboard: step 6, image 1 of 3 HTC Amaze Motherboard Replacement, Motherboard: step 6, image 2 of 3 HTC Amaze Motherboard Replacement, Motherboard: step 6, image 3 of 3
      • Locate and remove the Phillips J000 screw.
      Ask FixBot
    2. HTC Amaze Motherboard Replacement: step 7, image 1 of 2 HTC Amaze Motherboard Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the power supply from the motherboard by gently pulling the end of the black wire with the precision tweezers.
      Ask FixBot
    3. HTC Amaze Motherboard Replacement: step 8, image 1 of 3 HTC Amaze Motherboard Replacement: step 8, image 2 of 3 HTC Amaze Motherboard Replacement: step 8, image 3 of 3
      • First, gently lift the black strip by pulling. It will take a little force and then it will disconnect.
      • Next remove the yellow mylar tape using the precision tweezers.
      Ask FixBot
    4. HTC Amaze Motherboard Replacement: step 9, image 1 of 3 HTC Amaze Motherboard Replacement: step 9, image 2 of 3 HTC Amaze Motherboard Replacement: step 9, image 3 of 3
      • Remove the jawbone connector that was under the mylar tape by gently pulling with the precision tweezers.
      • Now gently pull the motherboard away from its housing. You'll now have access to the bottom side of the motherboard.
      Ask FixBot
    5. HTC Amaze Motherboard Replacement: step 10, image 1 of 3 HTC Amaze Motherboard Replacement: step 10, image 2 of 3 HTC Amaze Motherboard Replacement: step 10, image 3 of 3
      • Locate a second jawbone connector covered by mylar tape at the bottom of the back of the motherboard.
      • Remove the tape by pulling gently with the precision tweezers.
      • Remove the jawbone connector with the precision tweezers.
      Ask FixBot
    6. HTC Amaze Motherboard Replacement: step 11, image 1 of 2 HTC Amaze Motherboard Replacement: step 11, image 2 of 2
      • Carefully pull the motherboard out of its recess.
      Ask FixBot
2 other people completed this guide.
Author
with
Akshat Shah
368 Reputation
3 Guides authored
USF Tampa, Team 16-3, Eyestone Fall 2016 Member of USF Tampa, Team 16-3, Eyestone Fall 2016
USFT-EYESTONE-F16S16G3
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 88
All Time: 1,074
