Up to 20% off select tools
HTC Amaze Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
92
All Time:
836
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
Use this guide to do a battery replacement on HTC Amaze. No tools are required for this guide and you can easily follow the steps to replace or remove a battery.
    1. HTC Amaze Battery Replacement, Battery: step 1, image 1 of 2 HTC Amaze Battery Replacement, Battery: step 1, image 2 of 2
      • Gently press the Release Button located at the bottom of the phone in order to remove the back panel of the device.
      Ask FixBot
    2. HTC Amaze Battery Replacement: step 2, image 1 of 1
      • Once you locate the battery, look for a notch below it.
      • Gently insert your fingernails into the notch.
      • Lift the battery out of its recess.
      Ask FixBot
2 other people completed this guide.
Author
with
Akshat Shah
368 Reputation
3 Guides authored
USF Tampa, Team 16-3, Eyestone Fall 2016 Member of USF Tampa, Team 16-3, Eyestone Fall 2016
USFT-EYESTONE-F16S16G3
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 92
All Time: 836
