Up to 20% off select tools
HTC 7 Surround Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
69
All Time:
684
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HTC 7 Surround Camera Replacement, Back Case: step 1, image 1 of 2 HTC 7 Surround Camera Replacement, Back Case: step 1, image 2 of 2
      • Remove the back cover of the device to access the internal components of the HTC 7 Surround.
      • To remove the back cover, use the circular hole to lift up the cover while holding the front of the device down.
      Ask FixBot
    2. HTC 7 Surround Camera Replacement: step 2, image 1 of 3 HTC 7 Surround Camera Replacement: step 2, image 2 of 3 HTC 7 Surround Camera Replacement: step 2, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the screws as directed.
      Ask FixBot
    3. HTC 7 Surround Camera Replacement: step 3, image 1 of 1
      • Separate the screen and back cover with the opening tool.
      Ask FixBot
    1. HTC 7 Surround Camera Replacement, Rear Camera: step 4, image 1 of 1
      • The camera is attached to the device by a sticky double-sided piece of tape. Insert the plastic opening tool under each side of the camera until it is removed from the tape.
      • The camera lens should then come off after enough force is applied, and room will be made for the replacement to be inserted.
      Ask FixBot
Author
with
Michael Ronning
389 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 69
All Time: 684
