HP8 1401 Speakers Replacement
  1. HP8 1401 Speakers Replacement, Back Panel: step 1, image 1 of 1
    • Using a Torx T4 screwdriver, remove the four 5 mm screws on the back panel.
  2. HP8 1401 Speakers Replacement: step 2, image 1 of 1
    • Insert the tip of a plastic opening tool in the seam between the front and back panels.
  3. HP8 1401 Speakers Replacement: step 3, image 1 of 2 HP8 1401 Speakers Replacement: step 3, image 2 of 2
    • Slide the plastic opening tool around all edges of the device until the back panel detaches.
    • Lift off the back panel.
  4. HP8 1401 Speakers Replacement, Speakers: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Using tweezers or your fingers, disconnect the two speaker cables by pulling them free of the socket connectors.
  5. HP8 1401 Speakers Replacement: step 5, image 1 of 1
    • Use a spudger to pry the speakers up and out of the case.
  6. HP8 1401 Speakers Replacement: step 6, image 1 of 1
    • After removing the speakers they should look like this.
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 31
All Time: 278
