HP-Compaq G71-329WM LCD Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
68
All Time:
516
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 30 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Community-Contributed Guide
Tools
    1. HP-Compaq G71-329WM LCD Replacement, LCD: step 1, image 1 of 1
      • Remove the 2 Screw covers from the lower sides of the Bezel
      Ask FixBot
    2. HP-Compaq G71-329WM LCD Replacement: step 2, image 1 of 1
      • Remove the 2 Screws using a PH#1
      Ask FixBot
    3. HP-Compaq G71-329WM LCD Replacement: step 3, image 1 of 1
      • Use a pick along the top and sides of the bezel to start removing the bezel. Use your fingers to gently pry from the bottom of the bezel while pulling up. Bezel is very fragile.
      Ask FixBot
    4. HP-Compaq G71-329WM LCD Replacement: step 4, image 1 of 1
      • Remove the 2 screws from the top of the frame, One on each side.
      Ask FixBot
    5. HP-Compaq G71-329WM LCD Replacement: step 5, image 1 of 1
      • Remove the 4 screws holding the LCD to the frame. 2 on each side.
      Ask FixBot
    6. HP-Compaq G71-329WM LCD Replacement: step 6, image 1 of 1
      • Lay the LCD down on the keyboard and remove the webcam cable (if you have one) and remove the video cable.
      Ask FixBot
Brent Norris
613 Reputation
1 Guide authored
Brents Computer Repair Member of Brents Computer Repair
Business
1 Member
12 Guides authored
1 Guide Comment
Video guide How to disassemble HP Compaq G71 https://youtu.be/TsoP3EdbHz8
Viktorya - Reply Share
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 68
All Time: 516
