HP x2 10-p010wm Screen Replacement
    1. HP x2 10-p010wm Screen Replacement, Screen: step 1, image 1 of 2 HP x2 10-p010wm Screen Replacement, Screen: step 1, image 2 of 2
      • Pull the screen away from the keyboard.
      Ask FixBot
    2. HP x2 10-p010wm Screen Replacement: step 2, image 1 of 2 HP x2 10-p010wm Screen Replacement: step 2, image 2 of 2
      • Insert a spudger into the space between the screen and computer and gently pry the two pieces apart. Continue this around the whole screen.
      Ask FixBot
    3. HP x2 10-p010wm Screen Replacement: step 3, image 1 of 1
      • Slowly disconnect the thin wire attaching the screen to the rest of the computer by holding one end and sliding it down.
      • Do not pull up too hard; slowly slide it towards the screen.
      Ask FixBot
    4. HP x2 10-p010wm Screen Replacement: step 4, image 1 of 3 HP x2 10-p010wm Screen Replacement: step 4, image 2 of 3 HP x2 10-p010wm Screen Replacement: step 4, image 3 of 3
      • Hold the screen with your thumb and push back on the plastic frame.
      • Slowly separate the plastic frame on all sides.
      • Be careful not to break the plastic frame.
      Ask FixBot
    5. HP x2 10-p010wm Screen Replacement: step 5, image 1 of 2 HP x2 10-p010wm Screen Replacement: step 5, image 2 of 2
      • Remove the frame.
      Ask FixBot
Nathan Ojala
317 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 20
Past 30 Days: 48
All Time: 707
