HP w2216h Video Port Board Replacement
    1. HP w2216h Video Port Board Replacement, Screen: step 1, image 1 of 1
      • 'Make sure you are grounded, the power supply is not connected and you are wearing safety goggles.
      • Use the Philips #000 screwdriver to remove the 4 round12mm screws on the back panel.
      Ask FixBot
    2. HP w2216h Video Port Board Replacement: step 2, image 1 of 2 HP w2216h Video Port Board Replacement: step 2, image 2 of 2
      • Using a Philips #000 head remove 2 flat 12 mm screws above stand mounting bracket.
      • Using a PH1 Philips head with the 150 mm flexible extension remove 1 Philips head screw under the stand mounting bracket.
      • Stand will easily pull off.
      Ask FixBot
    3. HP w2216h Video Port Board Replacement: step 3, image 1 of 3 HP w2216h Video Port Board Replacement: step 3, image 2 of 3 HP w2216h Video Port Board Replacement: step 3, image 3 of 3
      • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
      • Turn monitor so that the screen is facing you.
      • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
      • The best places to pry are in the lower left and lower right corners of the black bezel.
      Ask FixBot
    4. HP w2216h Video Port Board Replacement: step 4, image 1 of 3 HP w2216h Video Port Board Replacement: step 4, image 2 of 3 HP w2216h Video Port Board Replacement: step 4, image 3 of 3
      • Be careful of the wires attaching the power button and the control buttons. Show extreme caution to ensure the button is not damaged.
      • Lift the screen assembly from the plastic housing from the corners.
      Ask FixBot
    5. HP w2216h Video Port Board Replacement: step 5, image 1 of 2 HP w2216h Video Port Board Replacement: step 5, image 2 of 2
      • Remove the 4 connectors from the left side of the monitor on the back.
      Ask FixBot
    6. HP w2216h Video Port Board Replacement: step 6, image 1 of 3 HP w2216h Video Port Board Replacement: step 6, image 2 of 3 HP w2216h Video Port Board Replacement: step 6, image 3 of 3
      • Lift the gray tape of the top of the monitor to expose the ribbon cable.
      • Remove the ribbon cable by sliding the connector towards the center of the screen assembly.
      • Lift the reflective tape next to the gray tape.
      Ask FixBot
    7. HP w2216h Video Port Board Replacement: step 7, image 1 of 3 HP w2216h Video Port Board Replacement: step 7, image 2 of 3 HP w2216h Video Port Board Replacement: step 7, image 3 of 3
      • Remove the 4 PH1 8mm Philips round screws on the outer edge of the screen's assembly.
      • Lift the screen from the screen assembly.
      Ask FixBot
    1. HP w2216h Video Port Board Replacement, Speakers: step 8, image 1 of 1
      • Remove the tape holding each speakers wire to the screen assembly.
      Ask FixBot
    2. HP w2216h Video Port Board Replacement: step 9, image 1 of 2 HP w2216h Video Port Board Replacement: step 9, image 2 of 2
      • Remove the two 8mm Philips #000 head screws on each speaker.
      Ask FixBot
    3. HP w2216h Video Port Board Replacement: step 10, image 1 of 2 HP w2216h Video Port Board Replacement: step 10, image 2 of 2
      • Remove the speakers by lifting them vertically from the screen assembly.
      Ask FixBot
    4. HP w2216h Video Port Board Replacement: step 11, image 1 of 1
      • Remove the cables that connects the speakers to the signal output board.
      Ask FixBot
    1. HP w2216h Video Port Board Replacement, Video Port Board: step 12, image 1 of 1
      • Remove the single Phillips #000 head screw above the HDMI port .
      Ask FixBot
    2. HP w2216h Video Port Board Replacement: step 13, image 1 of 1
      • Remove the two 2.5mm hex screws on either side of the VGA port
      Ask FixBot
    3. HP w2216h Video Port Board Replacement: step 14, image 1 of 3 HP w2216h Video Port Board Replacement: step 14, image 2 of 3 HP w2216h Video Port Board Replacement: step 14, image 3 of 3
      • Remove all 8mm Phillips #000 screws holding the board in place.
      • Remove the ribbon cable towards the bottom of the board by sliding the cable away from the board.
      • Remove both wire busses still on the board.
      Ask FixBot
    4. HP w2216h Video Port Board Replacement: step 15, image 1 of 1
      • Lift the board out of the screen assembly by first pulling the board away from the wall where the ports mount, then upward.
      Ask FixBot
Branflakes222
399 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 69
All Time: 1,001
