Up to 20% off select tools
HP w2216h Power Button Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
97
All Time:
1,478
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Is your monitor not powering on? Is the power button making a weird clicking noise? You might need to replace the power button.
    1. HP w2216h Power Button Replacement, Power Button: step 1, image 1 of 3 HP w2216h Power Button Replacement, Power Button: step 1, image 2 of 3 HP w2216h Power Button Replacement, Power Button: step 1, image 3 of 3
      • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
      • Turn monitor so that the screen is facing you.
      • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
      • The best places to pry are in the lower left and lower right corners of the black bezel.
      Ask FixBot
    2. HP w2216h Power Button Replacement: step 2, image 1 of 1
      • Do not pull the screen away to hard, this could snap the power cable.
      • Remove the power button from the top of the plastic frame.
      Ask FixBot
    3. HP w2216h Power Button Replacement: step 3, image 1 of 1
      • Remove the power cable by carefully sliding it out of it's plug.
      • Check if there is any tear or fray in the cable.
      Ask FixBot
2 other people completed this guide.
Author
with
Sadeq Taha
219 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 97
All Time: 1,478
