HP rp5700 Hard Drive Replacement
  1. HP rp5700 Hard Drive Replacement, Cover Removal: step 1, image 1 of 1
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
    Ask FixBot
  2. HP rp5700 Hard Drive Replacement: step 2, image 1 of 2 HP rp5700 Hard Drive Replacement: step 2, image 2 of 2
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
    Ask FixBot
  3. HP rp5700 Hard Drive Replacement: step 3, image 1 of 3 HP rp5700 Hard Drive Replacement: step 3, image 2 of 3 HP rp5700 Hard Drive Replacement: step 3, image 3 of 3
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
    Ask FixBot
  4. HP rp5700 Hard Drive Replacement, Hard Drive: step 4, image 1 of 2 HP rp5700 Hard Drive Replacement, Hard Drive: step 4, image 2 of 2
    • Using your right hand, grip the CD drive and lift it up to a 90 degree position.
    Ask FixBot
  5. HP rp5700 Hard Drive Replacement: step 5, image 1 of 2 HP rp5700 Hard Drive Replacement: step 5, image 2 of 2
    • Use your hand, whichever you prefer, to grip the two cords on the CD drive and remove the two cords by pulling up.
    • Repeat the same process to remove the two cords connected to the Hard Drive.
    Ask FixBot
  6. HP rp5700 Hard Drive Replacement: step 6, image 1 of 1
    • Use your right index finger to pull forward the green flap on the side of the hard drive.
    • At the same time as you are lifting the green flap, use your left hand to lift the hard drive up and out.
    Ask FixBot
8 other people completed this guide.
Alyssa Briones
1,750 Reputation
9 Guides authored
Cal Poly, Team 6-23, Maness Winter 2014 Member of Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
4 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 74
All Time: 4,514
