HP m8226x Power Supply Replacement
  1. HP m8226x Power Supply Replacement, HP m8226x Power Supply: step 1, image 1 of 3 HP m8226x Power Supply Replacement, HP m8226x Power Supply: step 1, image 2 of 3 HP m8226x Power Supply Replacement, HP m8226x Power Supply: step 1, image 3 of 3
    • Turn off your computer and remove the power cord by pulling it straight out of its socket.
    Ask FixBot
  2. HP m8226x Power Supply Replacement: step 2, image 1 of 3 HP m8226x Power Supply Replacement: step 2, image 2 of 3 HP m8226x Power Supply Replacement: step 2, image 3 of 3
    • Remove the two screws holding the right (from the back) case door to the computer.
    Ask FixBot
  3. HP m8226x Power Supply Replacement: step 3, image 1 of 3 HP m8226x Power Supply Replacement: step 3, image 2 of 3 HP m8226x Power Supply Replacement: step 3, image 3 of 3
    • Remove the side case door by pulling the tab towards the back of the computer with your hand.
    • Pull the door outward to remove it.
    Ask FixBot
  4. HP m8226x Power Supply Replacement: step 4, image 1 of 2 HP m8226x Power Supply Replacement: step 4, image 2 of 2
    • Remove the four screws holding in the power supply.
    Ask FixBot
  5. HP m8226x Power Supply Replacement: step 5, image 1 of 1
    • Lay the computer on its side to make it easier to remove the wiring.
    Ask FixBot
  6. HP m8226x Power Supply Replacement: step 6, image 1 of 3 HP m8226x Power Supply Replacement: step 6, image 2 of 3 HP m8226x Power Supply Replacement: step 6, image 3 of 3
    • Remove the computer processor's power cord by pinching the clip on the connector and pulling it straight out.
    Ask FixBot
  7. HP m8226x Power Supply Replacement: step 7, image 1 of 3 HP m8226x Power Supply Replacement: step 7, image 2 of 3 HP m8226x Power Supply Replacement: step 7, image 3 of 3
    • Remove the power cord from the optical disc drive by pulling it straight out.
    Ask FixBot
  8. HP m8226x Power Supply Replacement: step 8, image 1 of 3 HP m8226x Power Supply Replacement: step 8, image 2 of 3 HP m8226x Power Supply Replacement: step 8, image 3 of 3
    • If the hard drive doesn't have a SATA port connector then move to step 9.
    • Disconnect the SATA port connector from the hard drive by pulling it straight out.
    Ask FixBot
  9. HP m8226x Power Supply Replacement: step 9, image 1 of 2 HP m8226x Power Supply Replacement: step 9, image 2 of 2
    • If the hard drive has a 4-pin Molex connector, pinch the two clips on the connector and pull it straight out to remove it.
    Ask FixBot
  10. HP m8226x Power Supply Replacement: step 10, image 1 of 3 HP m8226x Power Supply Replacement: step 10, image 2 of 3 HP m8226x Power Supply Replacement: step 10, image 3 of 3
    • Remove the power to the motherboard by pinching the clip and pulling it straight out.
    Ask FixBot
  11. HP m8226x Power Supply Replacement: step 11, image 1 of 2 HP m8226x Power Supply Replacement: step 11, image 2 of 2
    • Remove the power supply by pushing it out from the back of the computer and lifting it out of the computer.
    Ask FixBot
2 other people completed this guide.
Scott Fisher
155 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 34
All Time: 1,376
