HP iPAQ h4155 Motherboard Replacement
    1. HP iPAQ h4155 Motherboard Replacement, Battery: step 1, image 1 of 1
      • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
      Ask FixBot
    2. HP iPAQ h4155 Motherboard Replacement: step 2, image 1 of 1
      • Push the tab left to right to remove the cover.
      Ask FixBot
    3. HP iPAQ h4155 Motherboard Replacement: step 3, image 1 of 1
      • Now, lift the battery up and away from the device to remove it.
      Ask FixBot
    1. HP iPAQ h4155 Motherboard Replacement, Back Case: step 4, image 1 of 1
      • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
      Ask FixBot
    2. HP iPAQ h4155 Motherboard Replacement: step 5, image 1 of 1
      • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
      Ask FixBot
    3. HP iPAQ h4155 Motherboard Replacement: step 6, image 1 of 2 HP iPAQ h4155 Motherboard Replacement: step 6, image 2 of 2
      • Next, use your plastic removal tool to separate the gray back from the black center piece.
      • For better results, start the separation at the corner piece.
      Ask FixBot
    4. HP iPAQ h4155 Motherboard Replacement: step 7, image 1 of 1
      • Remove the back case.
      Ask FixBot
    1. HP iPAQ h4155 Motherboard Replacement, Face Plate: step 8, image 1 of 1
      • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
      Ask FixBot
    2. HP iPAQ h4155 Motherboard Replacement: step 9, image 1 of 2 HP iPAQ h4155 Motherboard Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Next, unlock and remove the ribbon cable.
      • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
      • The bar, the connector, and the cable are fragile components that are easily broken.
      Ask FixBot
    3. HP iPAQ h4155 Motherboard Replacement: step 10, image 1 of 2 HP iPAQ h4155 Motherboard Replacement: step 10, image 2 of 2
      • Next, remove the wire from the bottom of the mother board.
      • The easiest method is to use metal tweezers and grip the plug closest to the connector.
      • Make sure all the connections are properly disconnected before separation from the motherboard.
      Ask FixBot
    4. HP iPAQ h4155 Motherboard Replacement: step 11, image 1 of 1
      • Next, use a plastic removal tool and separate the silver front case from the black frame.
      Ask FixBot
    1. HP iPAQ h4155 Motherboard Replacement, Motherboard: step 12, image 1 of 1
      • Now that the front cover is removed we will need to disconnect the LCD screen from the mother board. Pull the LCD connection out of the slot to properly disconnect.
      Ask FixBot
    2. HP iPAQ h4155 Motherboard Replacement: step 13, image 1 of 1
      Buy
      • Next we will need to remove the last wire from the motherboard
      • The easiest method is to grab and pull with metal tweezers near the bottom of the plug near the connector.
      Ask FixBot
    3. HP iPAQ h4155 Motherboard Replacement: step 14, image 1 of 2 HP iPAQ h4155 Motherboard Replacement: step 14, image 2 of 2
      • Finally the mother board can be removed from the center black frame.
      Ask FixBot
John Pagliero
957 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 35
All Time: 1,518
