HP iPAQ h4155 Face Plate Replacement
    1. HP iPAQ h4155 Face Plate Replacement, Battery: step 1, image 1 of 1
      • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
      Ask FixBot
    2. HP iPAQ h4155 Face Plate Replacement: step 2, image 1 of 1
      • Push the tab left to right to remove the cover.
      Ask FixBot
    3. HP iPAQ h4155 Face Plate Replacement: step 3, image 1 of 1
      • Now, lift the battery up and away from the device to remove it.
      Ask FixBot
    1. HP iPAQ h4155 Face Plate Replacement, Back Case: step 4, image 1 of 1
      • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
      Ask FixBot
    2. HP iPAQ h4155 Face Plate Replacement: step 5, image 1 of 1
      • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
      Ask FixBot
    3. HP iPAQ h4155 Face Plate Replacement: step 6, image 1 of 2 HP iPAQ h4155 Face Plate Replacement: step 6, image 2 of 2
      • Next, use your plastic removal tool to separate the gray back from the black center piece.
      • For better results, start the separation at the corner piece.
      Ask FixBot
    4. HP iPAQ h4155 Face Plate Replacement: step 7, image 1 of 1
      • Remove the back case.
      Ask FixBot
    1. HP iPAQ h4155 Face Plate Replacement, Face Plate: step 8, image 1 of 1
      • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
      Ask FixBot
    2. HP iPAQ h4155 Face Plate Replacement: step 9, image 1 of 2 HP iPAQ h4155 Face Plate Replacement: step 9, image 2 of 2
      Tool used on this step:
      Buy
      • Next, unlock and remove the ribbon cable.
      • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
      • The bar, the connector, and the cable are fragile components that are easily broken.
      Ask FixBot
    3. HP iPAQ h4155 Face Plate Replacement: step 10, image 1 of 2 HP iPAQ h4155 Face Plate Replacement: step 10, image 2 of 2
      • Next, remove the wire from the bottom of the mother board.
      • The easiest method is to use metal tweezers and grip the plug closest to the connector.
      • Make sure all the connections are properly disconnected before separation from the motherboard.
      Ask FixBot
    4. HP iPAQ h4155 Face Plate Replacement: step 11, image 1 of 1
      • Next, use a plastic removal tool and separate the silver front case from the black frame.
      Ask FixBot
John Pagliero
957 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 34
All Time: 1,880
