HP iPAQ H3850 Screen Replacement
    1. HP iPAQ H3850 Screen Replacement, Screen: step 1, image 1 of 1
      • To begin the disassembly of the device, place it on a flat surface with the screen facing down.
      Ask FixBot
    2. HP iPAQ H3850 Screen Replacement: step 2, image 1 of 1
      • Remove the four screws found on the back cover of the device.
      Ask FixBot
    3. HP iPAQ H3850 Screen Replacement: step 3, image 1 of 1
      • Carefully remove the back cover using the spudger against the grooves along the sides of the iPAQ.
      Ask FixBot
    4. HP iPAQ H3850 Screen Replacement: step 4, image 1 of 1
      • At this point, a yellow ribbon will be connecting both the front and back panels of the device. Carefully use the plastic opening tool to detach the ribbon from the connector pins.
      Ask FixBot
    5. HP iPAQ H3850 Screen Replacement: step 5, image 1 of 1
      • Remove SD card on top of device by pushing and then releasing.
      Ask FixBot
    6. HP iPAQ H3850 Screen Replacement: step 6, image 1 of 1
      • Remove the ribbon cable connected to display logic board by pulling the plastic clips on both sides towards top of device.
      • Use plastic opening tool to carefully pull brown ribbon cable from connector.
      Ask FixBot
    7. HP iPAQ H3850 Screen Replacement: step 7, image 1 of 3 HP iPAQ H3850 Screen Replacement: step 7, image 2 of 3 HP iPAQ H3850 Screen Replacement: step 7, image 3 of 3
      • Use the plastic opening tool to carefully remove the display logic board from its housing.
      • Unplug connector from the opposite end of the display logic board.
      • Completely remove component.
      Ask FixBot
    8. HP iPAQ H3850 Screen Replacement: step 8, image 1 of 1
      • Flip up black plastic clip on large ribbon cable connector located towards center of mother board.
      • Use plastic opening tool to carefully remove ribbon cable from connector.
      Ask FixBot
    9. HP iPAQ H3850 Screen Replacement: step 9, image 1 of 1
      Tool used on this step:
      Buy
      • Locate clear/grey ribbon cable in bottom corner of device.
      • Gently pry cable out of connector with plastic opening tool.
      • Use hands or tweezers to remove if necessary.
      Ask FixBot
    10. HP iPAQ H3850 Screen Replacement: step 10, image 1 of 1
      • Use your hands to gently unplug the speaker and microphone connectors from the mother board.
      Ask FixBot
    11. HP iPAQ H3850 Screen Replacement: step 11, image 1 of 1
      • Remove three small screws from each corner of the motherboard using phillips head screwdriver.
      • Use your hands/plastic opening tool to carefully lift the mother board out of housing.
      • Place the motherboard to the side.
      Ask FixBot
    12. HP iPAQ H3850 Screen Replacement: step 12, image 1 of 1
      • Locate the four blue plastic clips surrounding the square screen housing.
      • Pry back clips with your hands.
      • Use the plastic opening tool to remove the entire screen assembly from the housing.
      Ask FixBot
      • Insert new screen into device.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 95
All Time: 946
