HP iPAQ H3850 Battery Replacement
    1. HP iPAQ H3850 Battery Replacement, Battery: step 1, image 1 of 2 HP iPAQ H3850 Battery Replacement, Battery: step 1, image 2 of 2
      • Place the device on a flat surface with the screen facing down.
      • Use a screwdriver to remove four screws from the back cover of the device.
      Ask FixBot
    2. HP iPAQ H3850 Battery Replacement: step 2, image 1 of 1
      • Push and release the SD card on edge of the device.
      • Slide the SD card out.
      Ask FixBot
    3. HP iPAQ H3850 Battery Replacement: step 3, image 1 of 1
      • Insert the end of a spudger between the front and back cover and slide it around the edge to release the clips holding them together.
      • Pry them two halves but don't pull them apart as it is still connected by a cable.
      Ask FixBot
    4. HP iPAQ H3850 Battery Replacement: step 4, image 1 of 1
      • Place a spudger or opening tool under the connector's edge and pry straight up to disconnect the yellow cable from the motherboard.
      • Make sure to pry under the edge of the connector itself, and not under the socket on the board. Otherwise, you risk permanently damaging the socket.
      • Work carefully: don't pry on or accidentally scrape any small, surface mounted components on the board.
      • To reconnect, align the connector carefully over its socket and press down with your fingertip—first on one of the short sides, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again.
      Ask FixBot
    5. HP iPAQ H3850 Battery Replacement: step 5, image 1 of 1
      • Using an iOpener to heat the battery cover and loosen the adhesive holding the battery to the chassis.
      • The glue holding in battery should now be loosened.
      • Use plastic opening tool to remove battery from the back cover.
      Ask FixBot
    6. HP iPAQ H3850 Battery Replacement: step 6, image 1 of 1
      • Once the old battery is removed, scrape off the old adhesive from the device backing with the prying tool.
      • To attach the new battery, apply an adhesive to each corner of the backing where the battery sits and place the device into the backing.
      • Allow the adhesive to set for half an hour.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
3 other people completed this guide.
3 Guide Comments
Does anyone know where nowadays is it possible to get one of those batteries? I’ve been all over the internet and so far found zero… ?
in_sympathy - Reply Share
HI @alexanderre! I have no idea if you're still looking for this battery or not, but if you are, post this question on the Answers forum. More eyes will see it there.
Amber Taus - Reply Share
Hi @amber
Thanks for a hint, will do 🙏
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 62
All Time: 2,482
