HP iPAQ H2200 Joypad Replacement
    1. HP iPAQ H2200 Joypad Replacement, Battery: step 1, image 1 of 1
      • Press and slide the battery cover tab to remove battery cover.
      Ask FixBot
    2. HP iPAQ H2200 Joypad Replacement: step 2, image 1 of 2 HP iPAQ H2200 Joypad Replacement: step 2, image 2 of 2
      • Pull on the black tab to lift the battery out of the battery compartment.
      Ask FixBot
    1. HP iPAQ H2200 Joypad Replacement, Main Board: step 3, image 1 of 1
      • Remove the stylus by sliding it out of the slot.
      Ask FixBot
    2. HP iPAQ H2200 Joypad Replacement: step 4, image 1 of 1
      • Remove the CF card by sliding it out of the slot at the top of the device.
      Ask FixBot
    3. HP iPAQ H2200 Joypad Replacement: step 5, image 1 of 1
      • Press down and push the black side strips toward the top of the device to remove them.
      Ask FixBot
    4. HP iPAQ H2200 Joypad Replacement: step 6, image 1 of 3 HP iPAQ H2200 Joypad Replacement: step 6, image 2 of 3 HP iPAQ H2200 Joypad Replacement: step 6, image 3 of 3
      • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
      Ask FixBot
    5. HP iPAQ H2200 Joypad Replacement: step 7, image 1 of 2 HP iPAQ H2200 Joypad Replacement: step 7, image 2 of 2
      • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
      Ask FixBot
    6. HP iPAQ H2200 Joypad Replacement: step 8, image 1 of 1
      • Open the LCD connector, where the orange strip attaches to the main board.
      Ask FixBot
    7. HP iPAQ H2200 Joypad Replacement: step 9, image 1 of 1
      • Carefully remove the orange LCD strip from the connector.
      Ask FixBot
    8. HP iPAQ H2200 Joypad Replacement: step 10, image 1 of 1
      • Unscrew the 2 screws located at each top corner of the main board.
      Ask FixBot
    9. HP iPAQ H2200 Joypad Replacement: step 11, image 1 of 1
      • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
      Ask FixBot
    1. HP iPAQ H2200 Joypad Replacement, Joypad: step 12, image 1 of 1
      • Press on the four joypad tabs on the back, and push it through and out the front.
      Ask FixBot
    2. HP iPAQ H2200 Joypad Replacement: step 13, image 1 of 1
      • Push the new joypad through the hole; the tabs will lock it into place.
      Ask FixBot
Tyler Andrews
209 Reputation
5 Guides authored
Cal Poly, Team 4-12, Forte Winter 2010 Member of Cal Poly, Team 4-12, Forte Winter 2010
CPSU-FORTE-W10S4G12
3 Members
35 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 31
All Time: 3,495
