HP eStation Zeen Volume Buttons Replacement
    1. HP eStation Zeen Volume Buttons Replacement, Volume Buttons: step 1, image 1 of 3 HP eStation Zeen Volume Buttons Replacement, Volume Buttons: step 1, image 2 of 3 HP eStation Zeen Volume Buttons Replacement, Volume Buttons: step 1, image 3 of 3
      • Use a metal spudger to remove the four screw caps.
      • Remove the four 6 mm screws using a Philips #0 screwdriver.
      Ask FixBot
    2. HP eStation Zeen Volume Buttons Replacement: step 2, image 1 of 3 HP eStation Zeen Volume Buttons Replacement: step 2, image 2 of 3 HP eStation Zeen Volume Buttons Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool and slide it along the edge to open the back panel.
      • Lift the back panel away from the device.
      Ask FixBot
    3. HP eStation Zeen Volume Buttons Replacement: step 3, image 1 of 1
      • Disconnect the battery clip with a plastic opening tool.
      • Be gentle as the connector is fragile.
      Ask FixBot
    4. HP eStation Zeen Volume Buttons Replacement: step 4, image 1 of 1
      • Remove the two 6 mm screws using a Philips #0 screwdriver.
      Ask FixBot
    5. HP eStation Zeen Volume Buttons Replacement: step 5, image 1 of 1
      • Pull the ribbon from the board.
      • Be gentle as the ribbon is fragile.
      Ask FixBot
dalton hale
508 Reputation
4 Guides authored
USF Tampa, Team 16-4, Eyestone Fall 2016 Member of USF Tampa, Team 16-4, Eyestone Fall 2016
USFT-EYESTONE-F16S16G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 42
All Time: 493
