HP eStation Zeen Ground Wire Replacement
    1. HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: step 1, image 1 of 3 HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: step 1, image 2 of 3 HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: step 1, image 3 of 3
      • Remove the screw caps using a metal spudger.
      • Remove the four 6 mm screws using a Phillips #0 screwdriver.
      Ask FixBot
    2. HP eStation Zeen Ground Wire Replacement: step 2, image 1 of 3 HP eStation Zeen Ground Wire Replacement: step 2, image 2 of 3 HP eStation Zeen Ground Wire Replacement: step 2, image 3 of 3
      • Insert a plastic opening tool into the case seam and slide it along the edges.
      • Lift and remove the back panel from the device.
      Ask FixBot
    3. HP eStation Zeen Ground Wire Replacement: step 3, image 1 of 1
      • Carefully disconnect the battery clip using small plastic spudger.
      • The clip is extremely fragile.
      Ask FixBot
    4. HP eStation Zeen Ground Wire Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Use tweezers to disconnect the ground wire from motherboard terminal.
      Ask FixBot
    5. HP eStation Zeen Ground Wire Replacement: step 5, image 1 of 1
      • Use a soldering iron to remove the ground wire.
      • Avoid touching or heating the motherboard.
      Ask FixBot
dalton hale
508 Reputation
4 Guides authored
USF Tampa, Team 16-4, Eyestone Fall 2016 Member of USF Tampa, Team 16-4, Eyestone Fall 2016
USFT-EYESTONE-F16S16G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 85
All Time: 705
