HP dv5-1125nr WLAN Card Replacement
    1. HP dv5-1125nr WLAN Card Replacement, Battery: step 1, image 1 of 1
      • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
      • Slide the switch to the left until the release clicks.
      Ask FixBot
    2. HP dv5-1125nr WLAN Card Replacement: step 2, image 1 of 1
      • Remove the battery.
      • The release switch may need to be held down while removing the battery.
      Ask FixBot
    1. HP dv5-1125nr WLAN Card Replacement, Hard Drive: step 3, image 1 of 2 HP dv5-1125nr WLAN Card Replacement, Hard Drive: step 3, image 2 of 2
      • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP dv5-1125nr WLAN Card Replacement: step 4, image 1 of 1
      • Remove the plastic hard drive cover.
      Ask FixBot
    3. HP dv5-1125nr WLAN Card Replacement: step 5, image 1 of 2 HP dv5-1125nr WLAN Card Replacement: step 5, image 2 of 2
      • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
      Ask FixBot
    4. HP dv5-1125nr WLAN Card Replacement: step 6, image 1 of 2 HP dv5-1125nr WLAN Card Replacement: step 6, image 2 of 2
      • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
      Ask FixBot
    5. HP dv5-1125nr WLAN Card Replacement: step 7, image 1 of 2 HP dv5-1125nr WLAN Card Replacement: step 7, image 2 of 2
      • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
      • Slide the hard drive out of the enclosure to complete the removal process.
      Ask FixBot
    1. HP dv5-1125nr WLAN Card Replacement, WLAN Card: step 8, image 1 of 1
      • Locate the wireless card and the two wires attached to it.
      • Caution: Prying on the WLAN card wires in the wrong direction could damage your wireless card. Make sure to lift straight up when removing the wires.
      • Using a plastic spudger tool, carefully lift up on each wire connecting the card to unsnap the connectors.
      Ask FixBot
    2. HP dv5-1125nr WLAN Card Replacement: step 9, image 1 of 2 HP dv5-1125nr WLAN Card Replacement: step 9, image 2 of 2
      • Locate the 2.5mm Phillips screw on the corner of the WLAN card and remove it using a Phillips #000 screwdriver.
      Ask FixBot
    3. HP dv5-1125nr WLAN Card Replacement: step 10, image 1 of 2 HP dv5-1125nr WLAN Card Replacement: step 10, image 2 of 2
      • Upon removing the screw, the WLAN card will pop up. Keeping a natural angle, slide the card out of the slot.
      • The card is now free from your computer.
      Ask FixBot
Cory Mayer
891 Reputation
2 Guides authored
Cal Poly, Team 9-15, Regan Spring 2014 Member of Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 30
All Time: 1,531
