HP dv5-1125nr Disk Drive Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
84
All Time:
1,171
Comments: 0
Go to guide comments
Completed: 0
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 - 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing your optical drive is not a complex process. Follow this guide to learn how!
Tools
    1. HP dv5-1125nr Disk Drive Replacement, Battery: step 1, image 1 of 1
      • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
      • Slide the switch to the left until the release clicks.
      Ask FixBot
    2. HP dv5-1125nr Disk Drive Replacement: step 2, image 1 of 1
      • Remove the battery.
      • The release switch may need to be held down while removing the battery.
      Ask FixBot
    1. HP dv5-1125nr Disk Drive Replacement, Disk Drive: step 3, image 1 of 2 HP dv5-1125nr Disk Drive Replacement, Disk Drive: step 3, image 2 of 2
      • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
      • Remove the CMOS panel cover.
      Ask FixBot
    2. HP dv5-1125nr Disk Drive Replacement: step 4, image 1 of 3 HP dv5-1125nr Disk Drive Replacement: step 4, image 2 of 3 HP dv5-1125nr Disk Drive Replacement: step 4, image 3 of 3
      • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
      • Using your hands, slide the remainder of the drive out of the computer.
      Ask FixBot
Nick Loey
1,715 Reputation
8 Guides authored
Cal Poly, Team 9-15, Regan Spring 2014 Member of Cal Poly, Team 9-15, Regan Spring 2014
CPSU-REGAN-S14S9G15
4 Members
120 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 84
All Time: 1,171
