HP ZBook STUDIO X360 G5 Battery Replacement
Video Overview
    1. HP ZBook STUDIO X360 G5 Battery Replacement, Opening Base Enclosure: step 1, image 1 of 3 HP ZBook STUDIO X360 G5 Battery Replacement, Opening Base Enclosure: step 1, image 2 of 3 HP ZBook STUDIO X360 G5 Battery Replacement, Opening Base Enclosure: step 1, image 3 of 3
      • Be sure to power off and unplug your device before you begin your repair.
      • Consider placing your device on an Anti-Static ESD Mat and/or wearing an Anti-Static Wrist Strap to protect laptop internals.
      • Close your laptop and turn it over so that the side without the HP logo is facing you.
      • Using the TR8 bit, loosen the quantity nine screws from the base of the device.
      • These screws are captive and do not require complete removal from base enclosure. Instead, simply loosen the screws and proceed to the next step.
      • If screws are removed, take note that two of the screws [circled in Red] are shorter than the rest.
      • Carefully separate the rear edge (near hinges) and sides of the base enclosure from the top cover using plastic prying tool [see linked HP instructional video].
      • Slide the base enclosure toward the rear of the laptop and remove.
      Ask FixBot
    2. HP ZBook STUDIO X360 G5 Battery Replacement, Remove Battery-Mount Screws: step 2, image 1 of 2 HP ZBook STUDIO X360 G5 Battery Replacement, Remove Battery-Mount Screws: step 2, image 2 of 2
      • While the base enclosure is removed, take the time to clean your laptop internals with a can of compressed air or an electronic air duster.
      • Remove the quantity eight "M2x3" screws using a PH1 screwdriver.
      • There are arrows next to the labels that will help you identify the screws.
      Ask FixBot
    3. HP ZBook STUDIO X360 G5 Battery Replacement, Disconnect Battery Connector: step 3, image 1 of 3 HP ZBook STUDIO X360 G5 Battery Replacement, Disconnect Battery Connector: step 3, image 2 of 3 HP ZBook STUDIO X360 G5 Battery Replacement, Disconnect Battery Connector: step 3, image 3 of 3
      • Partially removing the battery might help in accessing the battery connector.
      • The 12-pin battery connector can be found just above the + and - symbols on the battery.
      • Use a spudger to gently pull the corners of the connector away from the white connector housing.
      • Alternate working each corner to avoid damaging the connector.
      Ask FixBot
    4. HP ZBook STUDIO X360 G5 Battery Replacement, Install New Battery: step 4, image 1 of 3 HP ZBook STUDIO X360 G5 Battery Replacement, Install New Battery: step 4, image 2 of 3 HP ZBook STUDIO X360 G5 Battery Replacement, Install New Battery: step 4, image 3 of 3
      • Gently place replacement battery into laptop, ensuring that the quantity two gray alignment pegs are properly seated in their respective mounting holes on the battery.
      • Carefully re-connect battery connector by gently pushing the corners of the connector into the white connector housing on the motherboard.
      • Re-install quantity 8 screws (removed in Step 2) to mount the battery to the inside of the laptop. Tighten screws until snug, being cautious not to strip the screw heads.
      • Follow "Battery Calibration Steps" below [see embedded picture] to ensure optimal performance of your new battery.
      • Charge your newly installed battery up to 100% and keep charging it for at least 2 more hours. Then, use your device until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
      Ask FixBot
To re-install the base enclosure, follow Step 1 in reverse order.
Zachary Perry
729 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 88
All Time: 692
