HP ZBook 15u G2 Heatsink Replacement
    1. HP ZBook 15u G2 Heatsink Replacement, Battery: step 1, image 1 of 1
      • Turn the HP Zbook over and flip the switch at the top so the red part is visible.
      Ask FixBot
    2. HP ZBook 15u G2 Heatsink Replacement: step 2, image 1 of 1
      • Pull the back cover down to remove it.
      Ask FixBot
    3. HP ZBook 15u G2 Heatsink Replacement: step 3, image 1 of 2 HP ZBook 15u G2 Heatsink Replacement: step 3, image 2 of 2
      • Flip the two switches on the top of the battery so the red is visible.
      Ask FixBot
    4. HP ZBook 15u G2 Heatsink Replacement: step 4, image 1 of 1
      • Lift the plastic tab at the top of the battery up to lift the battery up and out of the device
      Ask FixBot
    1. HP ZBook 15u G2 Heatsink Replacement, Heatsink: step 5, image 1 of 2 HP ZBook 15u G2 Heatsink Replacement, Heatsink: step 5, image 2 of 2
      Tool used on this step:
      Buy
      • Use a torx 8 screwdriver to remove the 11 M2.5x5mm torx screws labeled M2.5x5.
      • Use a pair of tweezers to remove the rubber feet at the edges and corners of the laptop to reveal the other 8 torx screws and remove them as well
      Ask FixBot
    2. HP ZBook 15u G2 Heatsink Replacement: step 6, image 1 of 1
      • Use a Phillips #00 screwdriver to remove the five M2.0x2 mm screws beneath the battery.
      Ask FixBot
    3. HP ZBook 15u G2 Heatsink Replacement: step 7, image 1 of 1
      • Remove the 4 mm Phillips screws under the SD card slot on the left of the laptop.
      • Lift the plastic edges around the bottom of the laptop to remove the bottom plastic cover.
      Ask FixBot
    4. HP ZBook 15u G2 Heatsink Replacement: step 8, image 1 of 2 HP ZBook 15u G2 Heatsink Replacement: step 8, image 2 of 2
      • Loosen the 2 silver Phillips screws on the fan assembly.
      • Remove the 6 Phillips screws at the left side of the heatsink assembly.
      Ask FixBot
    5. HP ZBook 15u G2 Heatsink Replacement: step 9, image 1 of 2 HP ZBook 15u G2 Heatsink Replacement: step 9, image 2 of 2
      • Using tweezers, gently unplug the wire the connects the fan to the motherboard.
      Ask FixBot
    6. HP ZBook 15u G2 Heatsink Replacement: step 10, image 1 of 1
      • Grip the heatsink assembly by the fan and lift it up to remove it.
      • Use computer duster to blow away and remove any dust and particles in and around the heatsink and fan assembly.
      Ask FixBot
Kwasi Sarfo
285 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 36
All Time: 723
