Tools
Introduction
Go to step 1 ↓Is the screen on your laptop malfunctioning? Here are some possible problems with your screen. If you determine that the screen needs to be replaced, follow this replacement guide!
Flip the laptop over.
Slide the lever with the battery symbol beside it firmly until the battery pops out.
Remove the battery from the laptop.
Tool used on this step:Tweezers$4.99
Orient the laptop keyboard-side up.
Use tweezers to remove the adhesive covers for the screws.
9 other people completed this guide.
3 Guide Comments
Worked great! Only caution that I would add is that on one of the machines I took apart, the adhesive strip behind the bottom of the bezel stuck to the bezel and not the circuit board behind. I had to carefully slide my finger between the adhesive strip and the bezel to separate them. Once the bezel was removed, I was able to stick the adhesive back down. I think this laptop may have been exposed to some sort of liquid, so this may not be a common issue.
Hello can i replace my hd screen with another fhd one?
