HP ZBook 15 Optical Drive Replacement
    1. HP ZBook 15 Optical Drive Replacement, Battery: step 1, image 1 of 2 HP ZBook 15 Optical Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop over.
      • Slide the lever with the battery symbol beside it firmly until the battery pops out.
      • Remove the battery from the laptop.
      Ask FixBot
    1. HP ZBook 15 Optical Drive Replacement, Back Cover: step 2, image 1 of 1
      • Slide the right lever firmly to the right.
      • Slide the cover towards yourself to remove it.
      Ask FixBot
    1. HP ZBook 15 Optical Drive Replacement, Optical Drive: step 3, image 1 of 1
      • Unscrew the captive screw shown near the battery compartment with a Phillips #0 screwdriver.
      • The screw does not come out all the way and stays attached to the computer.
      Ask FixBot
    2. HP ZBook 15 Optical Drive Replacement: step 4, image 1 of 3 HP ZBook 15 Optical Drive Replacement: step 4, image 2 of 3 HP ZBook 15 Optical Drive Replacement: step 4, image 3 of 3
      • Push outward on the metal optical drive tab with a metal spudger to unlock the drive from its position in the case.
      • Once the drive is protruding from the side of the computer, pull it the rest of the way out.
      Ask FixBot
4 other people completed this guide.
Grant Terris
2,888 Reputation
12 Guides authored
Cal Poly, Team 8-43, Amido Winter 2015 Member of Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Members
144 Guides authored
2 Guide Comments
Mine won't come out and now I think my silver tab is bent. Please help me!
Sajid - Reply Share
Oddly enough, mine came with no DVD drive but a blanking… thing, which seems to be a trimmed-down version of this official adapter (HP SPS 734298-001) without the electronics. I bought a cheap chinese ODD caddy, tore it down and salvaged the logic board. Luckily, I got everything lined up after a few adjustments (the chinese logic board is a bit longer than the HP one).
Now I’m rocking an extra drive bay without paying the $75 some shops ask for the official one.
I use it as swappable storage (not hot-swappable, mind you) . Very handy for doing drive imaging and cloning when working as an IT technician out in the field.
Luis Alejandro Araúz - Reply Share
Past 24 Hours: 4
Past 7 Days: 27
Past 30 Days: 123
All Time: 7,659
