HP ZBook 15 Hard Drive Replacement
    1. HP ZBook 15 Hard Drive Replacement, Battery: step 1, image 1 of 2 HP ZBook 15 Hard Drive Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop over.
      • Slide the lever with the battery symbol beside it firmly until the battery pops out.
      • Remove the battery from the laptop.
      Ask FixBot
    1. HP ZBook 15 Hard Drive Replacement, Back Cover: step 2, image 1 of 1
      • Slide the right lever firmly to the right.
      • Slide the cover towards yourself to remove it.
      Ask FixBot
    1. HP ZBook 15 Hard Drive Replacement, HP ZBook 15 Hard Drive Disassembly: step 3, image 1 of 1
      • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
      • The screws will remain inside the springs of the hard drive caddy cover.
      Ask FixBot
    2. HP ZBook 15 Hard Drive Replacement: step 4, image 1 of 2 HP ZBook 15 Hard Drive Replacement: step 4, image 2 of 2
      • Pull the green tab away from the metal casing and lift the drive out.
      Ask FixBot
    1. HP ZBook 15 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Remove the two 3mm screws on either side of the device with a Phillips #0 screwdriver to remove the drive caddy.
      Ask FixBot
13 other people completed this guide.
Grant Terris
2,888 Reputation
12 Guides authored
Cal Poly, Team 8-43, Amido Winter 2015 Member of Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Members
144 Guides authored
3 Guide Comments
You can use Macrium Reflect (there's a free non-commercial version) to backup your disk to an external drive before swapping the drive.
Paul M - Reply Share
There is written 'SSD' on its cover, and I'm confused now. Actually I need to disconnect the HDD and then install new OS on the SSD, and now I'm not sure if the drive that you just removed is SSD or HDD because on mine it say SSD. Please help me out.
Sajid - Reply Share
how hard disk i can buy for my zbook 15?
thanks
francesco perego - Reply Share
Past 24 Hours: 7
Past 7 Days: 50
Past 30 Days: 205
All Time: 32,176
