HP ZBook 15 Hard Drive Disassembly
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. HP ZBook 15 Hard Drive Disassembly, Battery: step 1, image 1 of 2 HP ZBook 15 Hard Drive Disassembly, Battery: step 1, image 2 of 2
      • Flip the laptop over.
      • Slide the lever with the battery symbol beside it firmly until the battery pops out.
      • Remove the battery from the laptop.
      Ask FixBot
    1. HP ZBook 15 Hard Drive Disassembly, Back Cover: step 2, image 1 of 1
      • Slide the right lever firmly to the right.
      • Slide the cover towards yourself to remove it.
      Ask FixBot
    1. HP ZBook 15 Hard Drive Disassembly, HP ZBook 15 Hard Drive Disassembly: step 3, image 1 of 1
      • Unscrew the three captive screws holding the drive in place with a Phillips #0 screwdriver.
      • The screws will remain inside the springs of the hard drive caddy cover.
      Ask FixBot
    2. HP ZBook 15 Hard Drive Disassembly: step 4, image 1 of 2 HP ZBook 15 Hard Drive Disassembly: step 4, image 2 of 2
      • Pull the green tab away from the metal casing and lift the drive out.
      Ask FixBot
Grant Terris
2,888 Reputation
12 Guides authored
Cal Poly, Team 8-43, Amido Winter 2015 Member of Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 12
Past 30 Days: 25
All Time: 571
