Up to 20% off select tools
HP ZBook 15 4G Network Module Replacement
Views: 6.2K
View statistics:
Past 24 Hours:
11
Past 7 Days:
29
Past 30 Days:
104
All Time:
6,152
Comments: 1
1 guide comment.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The ZBook 15 comes with a 4G wireless network module that allows you to connect to the internet via a SIM card provided by a wireless network company. If you need to replace the 4G network module on your laptop, follow this guide!
    1. HP ZBook 15 4G Network Module Replacement, Battery: step 1, image 1 of 2 HP ZBook 15 4G Network Module Replacement, Battery: step 1, image 2 of 2
      • Flip the laptop over.
      • Slide the lever with the battery symbol beside it firmly until the battery pops out.
      • Remove the battery from the laptop.
      Ask FixBot
    1. HP ZBook 15 4G Network Module Replacement, Back Cover: step 2, image 1 of 1
      • Slide the right lever firmly to the right.
      • Slide the cover towards yourself to remove it.
      Ask FixBot
    1. HP ZBook 15 4G Network Module Replacement, 4G Network Module: step 3, image 1 of 1
      • Remove the two connectors by lifting gently with a metal spudger.
      Ask FixBot
    2. HP ZBook 15 4G Network Module Replacement: step 4, image 1 of 2 HP ZBook 15 4G Network Module Replacement: step 4, image 2 of 2
      • Remove the 3mm screw with a Phillips #0 screwdriver.
      • Remove the 4G Module by lifting up and out.
      Ask FixBot
3 other people completed this guide.
Author
with
Grant Terris
2,888 Reputation
12 Guides authored
Cal Poly, Team 8-43, Amido Winter 2015 Member of Cal Poly, Team 8-43, Amido Winter 2015
CPSU-AMIDO-W15S8G43
4 Members
144 Guides authored
1 Guide Comment
this instructions were very useful
PRINCE - Reply Share
Past 24 Hours: 11
Past 7 Days: 29
Past 30 Days: 104
All Time: 6,152
