HP ZBOOK 15 G5 Motherboard Replacement
Views: 10K
View statistics:
Past 24 Hours:
5
Past 7 Days:
76
Past 30 Days:
285
All Time:
10,342
Comments: 4
4 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 - 40 minutes
Difficulty: Moderate
Community-Contributed Guide
    1. HP ZBOOK 15 G5 Motherboard Replacement, Opening the Bottom Panel: step 1, image 1 of 1
      • Find the bottom panel locking mechanism
      • Move the switch to the right to unlock and slide it in a downwards fashion
      Ask FixBot
    2. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Battery: step 2, image 1 of 1
      • Slide the battery latches to the right to loosen the battery
      • Remove the battery and place it to the side
      Ask FixBot
    3. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Keyboard: step 3, image 1 of 2 HP ZBOOK 15 G5 Motherboard Replacement, Removing the Keyboard: step 3, image 2 of 2
      • Unscrew the three keyboard screws on the bottom
      • While placing the laptop on it's side, push through the hole to release the keyboard
      • Once the latch releases, flip over the laptop and disconnect the three connectors as well
      • Place the keyboard to the side and flip the laptop over again
      Ask FixBot
    4. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Bottom Case: step 4, image 1 of 1
      • Remove these screws with a T8 screwdriver
      • Remove these screws with a philips screwdriver
      • Once they are removed, carefully lift up the bottom case
      Ask FixBot
    5. HP ZBOOK 15 G5 Motherboard Replacement, Removing SSD and LCD Connector Cover: step 5, image 1 of 1
      • Unscrew SSD screw and slide the SSD out
      • Remove these screws and place the LCD connector cover to the side
      • Disconnect all of the motherboard connectors
      Ask FixBot
    6. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Fans: step 6, image 1 of 1
      • Unscrew all of the screws on the fans (Keep in mind the screw don't come all of the way out)
      • Make sure to disconnect the fan connectors before removing it
      Ask FixBot
    7. HP ZBOOK 15 G5 Motherboard Replacement, Removing the Motherboard: step 7, image 1 of 1
      • Unscrew the motherboard screws
      • Make sure the SD card holder has been removed
      • Remove the motherboard and place it to the side
      Ask FixBot
      • Place the new motherboard in and screw it into place
      • Screw in the fans and reconnect the motherboard cables
      • Reconnect the LCD connectors
      • Screw the bottom case back onto the laptop
      • Connect the battery and put the battery cover back into place
      Ask FixBot
Once the repair had been done. Call the user and let them know their laptop is ready for pick-up
6 other people completed this guide.
Ved Pitre
1,308 Reputation
5 Guides authored
4 Guide Comments
Is it necessary to remove the keyboard if one is just swapping out the fans?
Burtimus - Reply Share
Answer: No, the keyboard does not have to be removed to swap out the fans .
My keyboard isn't work how i can remove it and clean it
Ayman Moftah - Reply Share
Thank you
Thank ypu
AHMED FAISAL HUMMADA - Reply Share
Past 24 Hours: 5
Past 7 Days: 76
Past 30 Days: 285
All Time: 10,342
