HP Z2 Mini G3 Real-Time Clock Battery Replacement
    1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Access Panel: step 1, image 1 of 1
      • Turn the device so the back-side of the device is facing you.
      • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
      • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
      Ask FixBot
    2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: step 2, image 1 of 2 HP Z2 Mini G3 Real-Time Clock Battery Replacement: step 2, image 2 of 2
      • Slide and hold the latch in the direction of the engraved arrow (to the right).
      Ask FixBot
    3. HP Z2 Mini G3 Real-Time Clock Battery Replacement: step 3, image 1 of 2 HP Z2 Mini G3 Real-Time Clock Battery Replacement: step 3, image 2 of 2
      • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
      Ask FixBot
    1. HP Z2 Mini G3 Real-Time Clock Battery Replacement, Real-Time Clock Battery: step 4, image 1 of 1
      • Rotate the device so the back-side is facing you and locate the RTC battery.
      • You may have to swing the CPU Fan and GPU Fan upwards to fully access the Real-Time Clock (RTC) Battery.
      Ask FixBot
    2. HP Z2 Mini G3 Real-Time Clock Battery Replacement: step 5, image 1 of 1
      • Press the battery down and away to free it of the latches.
      • Use your hand to grab and lift the battery out of the socket.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 30
Past 30 Days: 162
All Time: 5,175
