HP Z2 Mini G3 Motherboard Replacement
    1. HP Z2 Mini G3 Motherboard Replacement, Access Panel: step 1, image 1 of 1
      • Turn the device so the back-side of the device is facing you.
      • Be sure that the power is off and the A/C power cord has been disconnected before starting. Removing hardware while the power is on could damage the device or harm yourself.
      • Components of the device are subject to static damage. Work on a hard, grounded surface to prevent damage to the workstation.
      Ask FixBot
    2. HP Z2 Mini G3 Motherboard Replacement: step 2, image 1 of 2 HP Z2 Mini G3 Motherboard Replacement: step 2, image 2 of 2
      • Slide and hold the latch in the direction of the engraved arrow (to the right).
      Ask FixBot
    3. HP Z2 Mini G3 Motherboard Replacement: step 3, image 1 of 2 HP Z2 Mini G3 Motherboard Replacement: step 3, image 2 of 2
      • While holding the latch, lift the access panel upwards and towards yourself and set it aside upside-down.
      Ask FixBot
    1. HP Z2 Mini G3 Motherboard Replacement, CPU Fan: step 4, image 1 of 1
      • Rotate the device so the front side is facing you (the side with the power button) and locate the CPU fan.
      Ask FixBot
    2. HP Z2 Mini G3 Motherboard Replacement: step 5, image 1 of 1
      • Swing the fan upward, to a 90-degree angle.
      Ask FixBot
    3. HP Z2 Mini G3 Motherboard Replacement: step 6, image 1 of 2 HP Z2 Mini G3 Motherboard Replacement: step 6, image 2 of 2
      • Carefully disconnect the CPU fan by pulling out the wires from the motherboard.
      Ask FixBot
    4. HP Z2 Mini G3 Motherboard Replacement: step 7, image 1 of 1
      • Swing the fan back down and carefully unhook the CPU fan notches by pulling each tab away from the heat sink holes.
      Ask FixBot
    5. HP Z2 Mini G3 Motherboard Replacement: step 8, image 1 of 1
      • Swing the fan up again and pull it out.
      Ask FixBot
    1. HP Z2 Mini G3 Motherboard Replacement, CPU Processor: step 9, image 1 of 3 HP Z2 Mini G3 Motherboard Replacement, CPU Processor: step 9, image 2 of 3 HP Z2 Mini G3 Motherboard Replacement, CPU Processor: step 9, image 3 of 3
      • Remove the 9mm Torx screw with a T15 Torx screwdriver to release the SSD assembly.
      • Lift the assembly upwards to remove it.
      Ask FixBot
    2. HP Z2 Mini G3 Motherboard Replacement: step 10, image 1 of 1
      • Pull the metal arm out from under the frame and lift it up. The frame should slide back from under the screw.
      Ask FixBot
    3. HP Z2 Mini G3 Motherboard Replacement: step 11, image 1 of 2 HP Z2 Mini G3 Motherboard Replacement: step 11, image 2 of 2
      • Lift the frame upward to gain access to the processor
      • Take note of a triangular mark on one of the corners of the processor and bracket it is mounted on. The triangles must be aligned together during reassembly.
      Ask FixBot
    4. HP Z2 Mini G3 Motherboard Replacement: step 12, image 1 of 1
      • Grip the processor on each side, carefully lifting it up.
      • Do not touch the underside of the processor. Doing so may damage the processor and prevent a connection to the motherboard.
      • Be careful inserting the new processor. The connectors on the new one and the motherboard are fragile and damage easily.
      Ask FixBot
    1. HP Z2 Mini G3 Motherboard Replacement, Motherboard: step 13, image 1 of 3 HP Z2 Mini G3 Motherboard Replacement, Motherboard: step 13, image 2 of 3 HP Z2 Mini G3 Motherboard Replacement, Motherboard: step 13, image 3 of 3
      • Remove the thermal sensor cable from the motherboard.
      • Grab and lift the cable from the chassis to finish removing the thermal sensor.
      Ask FixBot
    2. HP Z2 Mini G3 Motherboard Replacement: step 14, image 1 of 1
      • Some models may have a wireless LAN module installed under the GPU fan.
      • In this case, use a T15 Torx screwdriver to remove the 9mm Torx screw from the module and take the component out.
      Ask FixBot
    3. HP Z2 Mini G3 Motherboard Replacement: step 15, image 1 of 1
      • Unplug, then carefully detach the system speaker from the chassis by gripping the frame and pulling back.
      • You do not need to remove the speaker from its frame.
      Ask FixBot
    4. HP Z2 Mini G3 Motherboard Replacement: step 16, image 1 of 2 HP Z2 Mini G3 Motherboard Replacement: step 16, image 2 of 2
      • Use a T15 Torx screw driver to remove the 9mm and the two 16mm Torx head screws that secure the motherboard to the chassis.
      Ask FixBot
    5. HP Z2 Mini G3 Motherboard Replacement: step 17, image 1 of 2 HP Z2 Mini G3 Motherboard Replacement: step 17, image 2 of 2
      • Slide the motherboard forward and to the left to clear it from chassis.
      • Carefully pull and lift the motherboard out by holding on to the ports.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 90
All Time: 4,033
