HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad Replacement
    1. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Batteries: step 1, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Batteries: step 1, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Batteries: step 1, image 3 of 3
      • Slide the rear compartment cover in the direction of the arrow.
      • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
      Ask FixBot
    1. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Shell: step 2, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Shell: step 2, image 2 of 2
      • Remove the four 4mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 3, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 3, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 3, image 3 of 3
      • Grip the main body and pull the joystick outwards until the entire front panel pops off.
      • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
      Ask FixBot
    3. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 4, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 4, image 2 of 2
      • Use a spudger to pry apart the two halves of the assembly.
      • Work slowly, prying a small section at a time until the halves are completely separated.
      Ask FixBot
    1. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Small Circuit Board: step 5, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Small Circuit Board: step 5, image 2 of 2
      • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
      Ask FixBot
    2. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 6, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 6, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 6, image 3 of 3
      • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
      • Release the blue flat cable by lifting up the white latch with a spudger.
      Ask FixBot
    1. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Touch Pad: step 7, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Touch Pad: step 7, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement, Touch Pad: step 7, image 3 of 3
      • Remove the two 6mm screws at the base of the rings using a Phillips #0 screwdriver.
      • Release the halo wire from the connector on the circuit board.
      • Pull the halo ring apart from the rest of the controller.
      Ask FixBot
    2. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 8, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 8, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 8, image 3 of 3
      • Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
      • Remove the V-clip from the device.
      Ask FixBot
    3. HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 9, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 9, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Touch Pad   Replacement: step 9, image 3 of 3
      • Unclip one of the tabs on the underside of the touch pad.
      • Using a spudger, pop off the touch pad.
      Ask FixBot
Seiji Nagasawa
219 Reputation
1 Guide authored
Cal Poly, Team S18-G5, White Winter 2019 Member of Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 17
All Time: 1,209
