HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement
  1. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Batteries: step 1, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Batteries: step 1, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Batteries: step 1, image 3 of 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
    Ask FixBot
  2. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Shell: step 2, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Shell: step 2, image 2 of 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
    Ask FixBot
  3. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: step 3, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: step 3, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: step 3, image 3 of 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
    Ask FixBot
  4. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: step 4, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: step 4, image 2 of 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
    Ask FixBot
  5. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Small Circuit Board: step 5, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement, Small Circuit Board: step 5, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
    Ask FixBot
  6. HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: step 6, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: step 6, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Small Circuit Board Replacement: step 6, image 3 of 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
    Ask FixBot
Clement Cheung
643 Reputation
5 Guides authored
Cal Poly, Team S18-G5, White Winter 2019 Member of Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Members
14 Guides authored
1 Guide Comment
Where would I be able to buy a replacement small board?
Emerald Wolf - Reply Share
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 941
