Up to 20% off select tools
HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
6
Past 7 Days:
13
Past 30 Days:
71
All Time:
1,397
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
  • Spudger
    4.9
  • Phillips #00 Screwdriver
    4.9
Introduction
Go to step 1 ↓
Follow this guide to open the housing on your HP Windows Mixed Reality Controllers TPC-Q044.
This guide goes over steps for the left controller, but the process is identical for the right controller.
Because most of the components in this device are enclosed within the housing, replacement for nearly all parts will require you to follow these instructions to access the internals.
    1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: step 1, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: step 1, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Batteries: step 1, image 3 of 3
      • Slide the rear compartment cover in the direction of the arrow.
      • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
      Ask FixBot
    1. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: step 2, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement, Shell: step 2, image 2 of 2
      • Remove the four 4mm screws using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: step 3, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: step 3, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: step 3, image 3 of 3
      • Grip the main body and pull the joystick outwards until the entire front panel pops off.
      • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
      Ask FixBot
    3. HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: step 4, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Shell Replacement: step 4, image 2 of 2
      • Use a spudger to pry apart the two halves of the assembly.
      • Work slowly, prying a small section at a time until the halves are completely separated.
      Ask FixBot
Author
with
Clement Cheung
643 Reputation
5 Guides authored
Cal Poly, Team S18-G5, White Winter 2019 Member of Cal Poly, Team S18-G5, White Winter 2019
CPSU-WHITE-W19S18G5
2 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 13
Past 30 Days: 71
All Time: 1,397
