HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement
  1. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: step 1, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: step 1, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Batteries: step 1, image 3 of 3
    • Slide the rear compartment cover in the direction of the arrow.
    • If replacing batteries, ensure the (+) and (-) on the battery match the (+) and (-) labeled in the battery compartment.
    Ask FixBot
  2. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: step 2, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Shell: step 2, image 2 of 2
    • Remove the four 4mm screws using a Phillips #00 screwdriver.
    Ask FixBot
  3. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 3, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 3, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 3, image 3 of 3
    • Grip the main body and pull the joystick outwards until the entire front panel pops off.
    • Remove the 6mm screw in the corner of the joystick well using a Phillips #00 screwdriver.
    Ask FixBot
  4. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 4, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 4, image 2 of 2
    • Use a spudger to pry apart the two halves of the assembly.
    • Work slowly, prying a small section at a time until the halves are completely separated.
    Ask FixBot
  5. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: step 5, image 1 of 2 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Small Circuit Board: step 5, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the four 4mm screws located on the joystick circuit board underneath the top half of the controller.
    Ask FixBot
  6. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 6, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 6, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 6, image 3 of 3
    • Remove the orange flat cable by pulling the orange tab parallel to the circuit board.
    • Release the blue flat cable by lifting up the white latch with a spudger.
    Ask FixBot
  7. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: step 7, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: step 7, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement, Main Circuit Board: step 7, image 3 of 3
    • Remove the two 6mm screws at the base of the ring using a Phillips #0 screwdriver.
    • Pull towards the base of the controller to release the black wire from the connector on the circuit board.
    • Pull the ring apart from the rest of the controller.
    Ask FixBot
  8. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 8, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 8, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 8, image 3 of 3
    • Remove the two 3mm screws on the V-clip using a Phillips #00 screwdriver.
    • Remove the V-clip from the device.
    Ask FixBot
  9. HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 9, image 1 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 9, image 2 of 3 HP Windows Mixed Reality Controllers TPC-Q044 Main Circuit Board Replacement: step 9, image 3 of 3
    • With the V-clip off of the controller, use a Phillips #00 screwdriver to remove the remaining 4mm screw.
    • Remove the circuit board.
    Ask FixBot
4 other people completed this guide.
Eeshan Mishra
424 Reputation
4 Guides authored
1 Guide Comment
Awesome! But were do you get the components to replace from??
Since separate controllers are very difficult to find and expensive (You wont find Samsung ones) I will be interested to buy a few to do repairs to friends and so.
Baba Nam Kevalam - Reply Share
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 40
All Time: 2,432
