HP Touchsmart IQ506 Stand Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
91
All Time:
782
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Replacing the stand on the HP IQ506.
The part number for the stand this system uses is the HP 507866-001 stand. Note: This part does not include screws. You will need to get the diameter with a digital caliper if you do not have the screws. I DO NOT have this information to hand right now.
Parts
Tools
  • Phillips #1 Screwdriver
    5
    Optional
    May be helpful in removing the stand screws if you do not own a Legacy Pro Tech as used at the time in this guide and are struggling.
    1. HP Touchsmart IQ506 Stand Replacement, Unplug the power supply: step 1, image 1 of 2 HP Touchsmart IQ506 Stand Replacement, Unplug the power supply: step 1, image 2 of 2
      • Unplug the power supply from the system.
      Ask FixBot
    2. HP Touchsmart IQ506 Stand Replacement, Remove the RAM door: step 2, image 1 of 3 HP Touchsmart IQ506 Stand Replacement, Remove the RAM door: step 2, image 2 of 3 HP Touchsmart IQ506 Stand Replacement, Remove the RAM door: step 2, image 3 of 3
      • Unscrew the RAM door from the system. Use a Phillips #1 screwdriver. Once you do this, unclip it from the bottom and pull forward.
      Ask FixBot
    3. HP Touchsmart IQ506 Stand Replacement, Screwdriver placement tip: step 3, image 1 of 1
      • THIS STEP ONLY APPLIES FOR LEGACY iFixit 54-BIT DRIVER KIT USERS.
      • When usjng the legacy driver handle, the top hinge screws can be difficult to get to. If you have the legacy 54-bit iFixit driver kit, lock the stand upright and slide it under the stand from the rear to access the top screws. This should be less of an issue with a standalone driver or modern driver kits like the 64-bit/Manta kit.
      Ask FixBot
    4. HP Touchsmart IQ506 Stand Replacement, Remove the stand: step 4, image 1 of 3 HP Touchsmart IQ506 Stand Replacement, Remove the stand: step 4, image 2 of 3 HP Touchsmart IQ506 Stand Replacement, Remove the stand: step 4, image 3 of 3
      • Remove the stand from the system. Use a Phillips #1 screwdriver to loosen the 4 screws. The stand will be loose and easily removed.
      Ask FixBot
Nick
106,443 Reputation
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 91
All Time: 782
