Up to 20% off select tools
HP Touchsmart IQ506 RAM (Memory) Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
3
Past 7 Days:
20
Past 30 Days:
101
All Time:
1,511
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
  • Pro Tech Go Toolkit
    $42.46 $49.95
    4.9
    The bits in the EET will suffice for this guide, but the additional tools could be useful in future repairs.
Introduction
Go to step 1 ↓
If your RAM has failed or you need to add more memory to your HP IQ500 Series AIO PC, this is how you would do the upgrade.
Maximum supported memory: 4GB
Required memory: DDR2 (SODIMM)
Supported speeds:
  • PC2-4200 (533MHz)
  • PC2-5300 (667 MHz)
  • PC2- 6400 (800MHz)
Note: While the system accepts PC2-5300, it is hard to find. If you find it, it tends to be rather expensive compared to PC2-6400. Your cheapest option for DDR2 is going to be PC2-6400.
    1. HP Touchsmart IQ506 RAM (Memory) Replacement, Change note: step 1, image 1 of 2 HP Touchsmart IQ506 RAM (Memory) Replacement, Change note: step 1, image 2 of 2
      Tool used on this step:
      Essential Electronics Toolkit
      $25.46
      Buy
      • Due to the EET missing several components present in the Pro Tech Go and only being $20 cheaper, the EET has been removed. The EET will work for this guide as-is, but if you are shopping for a new toolkit to complete this guide, the Pro Tech Go (new or refurbished, refurbished is ~$32 cheaper), or Pro Tech ($79 new/~$59.95 refurb) is the current recommended toolkit for this guide.
      • If you are interested in a refurbished kit stock levels change frequently but can be found here.
      Ask FixBot
    1. HP Touchsmart IQ506 RAM (Memory) Replacement, Unplug the system: step 2, image 1 of 2 HP Touchsmart IQ506 RAM (Memory) Replacement, Unplug the system: step 2, image 2 of 2
      • Unplug the power brick from the system.
      Ask FixBot
    2. HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM door: step 3, image 1 of 3 HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM door: step 3, image 2 of 3 HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM door: step 3, image 3 of 3
      • Unscrew the RAM door using a Phillips #1 screwdriver. Snap the RAM door off from the bottom and slide it off.
      Ask FixBot
    3. HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM: step 4, image 1 of 2 HP Touchsmart IQ506 RAM (Memory) Replacement, Remove the RAM: step 4, image 2 of 2
      • With the RAM exposed, remove the RAM from the slots on the system by pushing the tabs back. Once you do this the RAM will pop up and you can remove it.
      • Install the new RAM. Make sure you line the tab up on the memory with the slot in the system. It should only go in one way.
      Ask FixBot
Author
with
Nick
107,133 Reputation
73 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 101
All Time: 1,511
