HP TouchSmart 15-r015dx Screen Replacement
    1. HP TouchSmart 15-r015dx Screen Replacement, Screen: step 1, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement, Screen: step 1, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement, Screen: step 1, image 3 of 3
      • Acquire the metal spudger and a Precision Magnetized Driver with J1 size bit.
      • Flip your HP TouchSmart 15 over.
      Ask FixBot
    2. HP TouchSmart 15-r015dx Screen Replacement: step 2, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 2, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 2, image 3 of 3
      • Locate tabs on the underside of the laptop.
      • Push both tabs towards the center of the laptop and pull away to remove battery.
      Ask FixBot
    3. HP TouchSmart 15-r015dx Screen Replacement: step 3, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 3, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 3, image 3 of 3
      • Take the sharp end of the pry tool and pop out the black screw cover.
      • Repeat on opposite side.
      Ask FixBot
    4. HP TouchSmart 15-r015dx Screen Replacement: step 4, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 4, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 4, image 3 of 3
      • Take the Precision Magnetized Driver with J1 size bit and unscrew the screw.
      Ask FixBot
    5. HP TouchSmart 15-r015dx Screen Replacement: step 5, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 5, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 5, image 3 of 3
      • Using the pry tool, begin to separate the touchscreen from the plastic backing.
      Ask FixBot
    6. HP TouchSmart 15-r015dx Screen Replacement: step 6, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 6, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 6, image 3 of 3
      • Close the laptop and flip it over once again.
      • Continue to pry the touchscreen from the plastic backing in the hinged area of the laptop.
      Ask FixBot
    7. HP TouchSmart 15-r015dx Screen Replacement: step 7, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 7, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 7, image 3 of 3
      • Flip over the laptop and open it.
      • Pull up on the separated touchscreen while pulling it away from the plastic backing.
      • Be careful while laying down the touchscreen to not pull the connection point.
      • Lay the touchscreen on the keyboard facedown.
      Ask FixBot
    8. HP TouchSmart 15-r015dx Screen Replacement: step 8, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 8, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 8, image 3 of 3
      • Locate the connection point.
      • Slowly and carefully peel off.
      Ask FixBot
    9. HP TouchSmart 15-r015dx Screen Replacement: step 9, image 1 of 2 HP TouchSmart 15-r015dx Screen Replacement: step 9, image 2 of 2
      • Isolate the touchscreen from the keyboard.
      Ask FixBot
    10. HP TouchSmart 15-r015dx Screen Replacement: step 10, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 10, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 10, image 3 of 3
      • Begin by peeling off the black adhesive tape using the pry tool.
      • Once adhesive tape is removed, use the pry tool to remove the tab in the corner. Repeat in each corner.
      Ask FixBot
    11. HP TouchSmart 15-r015dx Screen Replacement: step 11, image 1 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 11, image 2 of 3 HP TouchSmart 15-r015dx Screen Replacement: step 11, image 3 of 3
      • Using the sharp end of the pry tool, separate the plastic from the screen.
      Ask FixBot
    12. HP TouchSmart 15-r015dx Screen Replacement: step 12, image 1 of 1
      • Now it is time to reassemble your device with a new screen.
      Ask FixBot
3 other people completed this guide.
1 Guide Comment
Amazing work. I would not change a thing.
Dan Hartzell - Reply Share
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 116
All Time: 1,725
