HP TouchSmart 15-r015dx Hard Drive Replacement
    1. HP TouchSmart 15-r015dx Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Turn off your laptop.
      • Ensure your laptop is off. Removing the battery while it is on may harm your laptop or yourself.
      • Flip over to view the bottom of the laptop in order to gain access the battery and the DVD±RW Drive.
      Ask FixBot
    2. HP TouchSmart 15-r015dx Hard Drive Replacement: step 2, image 1 of 1
      • There are two battery release switches circled.
      Ask FixBot
    3. HP TouchSmart 15-r015dx Hard Drive Replacement: step 3, image 1 of 1
      • slide release switches inward towards each other to release battery.
      Ask FixBot
    4. HP TouchSmart 15-r015dx Hard Drive Replacement: step 4, image 1 of 1
      • after sliding the release switches, pull battery towards yourself to remove battery.
      Ask FixBot
    1. HP TouchSmart 15-r015dx Hard Drive Replacement, DVD±RW Drive: step 5, image 1 of 2 HP TouchSmart 15-r015dx Hard Drive Replacement, DVD±RW Drive: step 5, image 2 of 2
      • There is one screw holding the DVD±RW Drive in place. Use the #00 screwdriver to remove the screw.
      Ask FixBot
    2. HP TouchSmart 15-r015dx Hard Drive Replacement: step 6, image 1 of 3 HP TouchSmart 15-r015dx Hard Drive Replacement: step 6, image 2 of 3 HP TouchSmart 15-r015dx Hard Drive Replacement: step 6, image 3 of 3
      • The DVD±RW Drive is here. Remove by gently pulling it straight out.
      • After removal of the DVD±RW Drive, two screws are exposed and must be removed.
      Ask FixBot
    1. HP TouchSmart 15-r015dx Hard Drive Replacement, Keyboard: step 7, image 1 of 2 HP TouchSmart 15-r015dx Hard Drive Replacement, Keyboard: step 7, image 2 of 2
      • Using your Phillips #00 screwdriver, remove the two screws to loosen the fittings of the keyboard.
      • One of the screws lies in the label.
      Ask FixBot
    2. HP TouchSmart 15-r015dx Hard Drive Replacement: step 8, image 1 of 3 HP TouchSmart 15-r015dx Hard Drive Replacement: step 8, image 2 of 3 HP TouchSmart 15-r015dx Hard Drive Replacement: step 8, image 3 of 3
      • Flip the laptop over to view the top and lift the screen up.
      • There are sixteen clips holding the keyboard in place. Gently pry up each clip using a plastic opening tool. Once all clips are loose, lift the keyboard from the computer.
      • Do NOT pull the keyboard up more than 2-3 inches as there is a film-material connecting the keyboard to the laptop.
      Ask FixBot
    3. HP TouchSmart 15-r015dx Hard Drive Replacement: step 9, image 1 of 3 HP TouchSmart 15-r015dx Hard Drive Replacement: step 9, image 2 of 3 HP TouchSmart 15-r015dx Hard Drive Replacement: step 9, image 3 of 3
      • There is a small black latch holding the film-material in place.
      • Flip the black latch up to release the film-material. Once flipped up, simply pull the film-material out from the laptop to release the keyboard.
      • There are tiny prongs on the ribbon; it must be carefully removed and upon re-installation the prongs must be lined up exactly in each tiny track in order for the keyboard to work.
      Ask FixBot
    1. HP TouchSmart 15-r015dx Hard Drive Replacement, Hard Drive: step 10, image 1 of 1
      • Flip the laptop over to view the bottom and remove the remaining screws from the bottom.
      • There are 2 screws located underneath the covers.
      Ask FixBot
    2. HP TouchSmart 15-r015dx Hard Drive Replacement: step 11, image 1 of 2 HP TouchSmart 15-r015dx Hard Drive Replacement: step 11, image 2 of 2
      • Flip your laptop over to view top and open it.
      • Remove the four screws and the two wires before removing the base of the laptop.
      • The metal prongs that wires fit onto stay attached to the computer and can be easily bent when trying to remove or place the plastic piece on to secure the wire. Also pay attention to how the plastic piece looks when you take them off (i.e. which side is up and facing out).
      Ask FixBot
    3. HP TouchSmart 15-r015dx Hard Drive Replacement: step 12, image 1 of 1
      • Use your plastic opening tool to pry the base of the laptop off.
      Ask FixBot
    4. HP TouchSmart 15-r015dx Hard Drive Replacement: step 13, image 1 of 3 HP TouchSmart 15-r015dx Hard Drive Replacement: step 13, image 2 of 3 HP TouchSmart 15-r015dx Hard Drive Replacement: step 13, image 3 of 3
      • There are two screws holding the hard drive in place. Remove these screws.
      • Remove the hard drive by pulling it to the right like shown.
      Ask FixBot
To reassemble your device and complete the hard drive replacement, please follow these instructions in reverse order.
37 other people completed this guide.
Jacob Kleinsorge
2,129 Reputation
5 Guides authored
USF Tampa, Team 16-4, Watkins Winter 2015 Member of USF Tampa, Team 16-4, Watkins Winter 2015
USFT-WATKINS-W15S16G4
4 Members
72 Guides authored
3 Guide Comments
Two things to add:
1. The two screws hidden under the DVD drive on the edge of the case must be removed.
2. It's easier to unlatch the ribbons for the keyboard, trackpad, and power button than it is to try and work around them. There are holes in the laptop base right over the ribbon connectors, so it's easy to re-connect them.
nullisland - Reply Share
I don't have the screws that hold the hard drive in place. Is there any way to get them seperatly?
Anonnymuz example - Reply Share
This thing is impossible to take apart I swear to god. I ended up just ripping it apart to remove the HDD and screen.
MitW - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 63
All Time: 32,313
