Tools
Introduction
Go to step 1 ↓Use this guide to replace the digitizer control board.
In the following steps, you will use a metal spudger to lift the front panel out from the rear case of your TouchPad.
Remove the two 3.0 mm Phillips screws securing the digitizer control board to the rear case.
Using the edge of a plastic opening tool or your fingernail, carefully flip up the retaining flap on the digitizer control board ribbon cable ZIF socket.
Pull the digitizer control board ribbon cable straight out of its socket on the digitizer control board.
Remove the digitizer control board from the TouchPad.
3 other people completed this guide.
4 Guide Comments
when my charger falled on the screen of my hp touchpad its screen did not break but its touchscreen is not working so which part i whant to change
