This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Community-Contributed Guide
Introduction
Go to step 1 ↓The printer stopped responding to power-on attempts and was no longer emitting any light. We suspected a power supply issue. It turned out that the power adapter was only providing the 32 V output. The 12 V output was missing. The power adapter was simply replaced.
Behind each of the round stickers is a Torx screw.
Use a screwdriver to release the 8 clips. These are evenly distributed around the device. To do this, pry off the light gray cover bit by bit.
The power supply is held loosely in the housing and is connected by a 3-pin connector.
When unplugging the connector, pull directly on the connector, not on the cables.
The power supply can be tested using a multimeter. There should be 12 V or 32 V between the center connector pin and the outer pins. Naturally, the power supply must be connected to a wall outlet with the power cable for this to work.
A replacement power supply can be ordered from several suppliers online for under €20.
Follow these steps in reverse order to reassemble your device.
