Up to 20% off select tools
HP Stream 8 Rear-facing camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
93
All Time:
801
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. HP Stream 8 Rear-facing camera Replacement, Midframe: step 1, image 1 of 1
      • Use your nail or a spudger to pry the back cover off of the device.
      Ask FixBot
    2. HP Stream 8 Rear-facing camera Replacement: step 2, image 1 of 1
      • Slide your finger around the rest of the back cover, lifting it completely off of the device.
      Ask FixBot
    3. HP Stream 8 Rear-facing camera Replacement: step 3, image 1 of 1
      • Remove ten Phillips #00 screws from the inside cover.
      Ask FixBot
    4. HP Stream 8 Rear-facing camera Replacement: step 4, image 1 of 1
      • Pry up the inside cover the same way as in the first step.
      Ask FixBot
    1. HP Stream 8 Rear-facing camera Replacement, Rear-Facing Camera: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
      Ask FixBot
    2. HP Stream 8 Rear-facing camera Replacement: step 6, image 1 of 1
      • Remove the back facing camera with the tweezers.
      Ask FixBot
Author
with
Nick Miller
669 Reputation
6 Guides authored
Cal Poly, Team 34-14, Maness Spring 2016 Member of Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 93
All Time: 801
