Up to 20% off select tools
HP Stream 8 Motherboard Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
8
Past 7 Days:
23
Past 30 Days:
99
All Time:
1,785
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Difficult
Better Introduction
Improve this guide by completing or revising its introduction.
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Tools
    1. HP Stream 8 Motherboard Replacement, Midframe: step 1, image 1 of 1
      • Use your nail or a spudger to pry the back cover off of the device.
      Ask FixBot
    2. HP Stream 8 Motherboard Replacement: step 2, image 1 of 1
      • Slide your finger around the rest of the back cover, lifting it completely off of the device.
      Ask FixBot
    3. HP Stream 8 Motherboard Replacement: step 3, image 1 of 1
      • Remove ten Phillips #00 screws from the inside cover.
      Ask FixBot
    4. HP Stream 8 Motherboard Replacement: step 4, image 1 of 1
      • Pry up the inside cover the same way as in the first step.
      Ask FixBot
    1. HP Stream 8 Motherboard Replacement, Front-Facing Camera: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
      Ask FixBot
    2. HP Stream 8 Motherboard Replacement: step 6, image 1 of 1
      • Remove the front facing camera with tweezers.
      Ask FixBot
    1. HP Stream 8 Motherboard Replacement, Rear-Facing Camera: step 7, image 1 of 1
      Buy
      • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
      Ask FixBot
    2. HP Stream 8 Motherboard Replacement: step 8, image 1 of 1
      • Remove the back facing camera with the tweezers.
      Ask FixBot
    1. HP Stream 8 Motherboard Replacement, Motherboard: step 9, image 1 of 1
      Buy
      • Carefully remove the battery connector from the system board using the tweezers.
      Ask FixBot
    2. HP Stream 8 Motherboard Replacement: step 10, image 1 of 1
      • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
      Ask FixBot
    3. HP Stream 8 Motherboard Replacement: step 11, image 1 of 1
      • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
      Ask FixBot
    4. HP Stream 8 Motherboard Replacement: step 12, image 1 of 1
      • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
      Ask FixBot
    5. HP Stream 8 Motherboard Replacement: step 13, image 1 of 1
      • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
      Ask FixBot
    6. HP Stream 8 Motherboard Replacement: step 14, image 1 of 1
      • Remove the motherboard from the device.
      Ask FixBot
Author
with
Nick Miller
669 Reputation
6 Guides authored
Cal Poly, Team 34-14, Maness Spring 2016 Member of Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 23
Past 30 Days: 99
All Time: 1,785
