Up to 20% off select tools
HP Stream 8 Battery Replacement
Views: 6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
26
Past 30 Days:
116
All Time:
5,961
Comments: 4
2 comments on steps, 2 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 40 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your HP Stream 8 model 5801 battery needs to be replaced because it has lost the ability to hold a charge, then this is the guide for you.
The battery provides power to the tablet. A faulty battery or battery that isn't able to hold a charge properly needs to be replaced.
Before using this guide, make sure you are using the original HP brand cable and AC/DC adapter. You should also make sure you have the adapter plugged directly into the wall outlet. If you charge your tablet for an hour and still have no charge, continue to follow this guide and replace your battery.
A punctured battery can cause a dangerous fire. If your battery is swollen, please review What to do with a swollen battery.
Before you begin, power down your device completely and disconnect from any power source.
    1. HP Stream 8 Battery Replacement, Midframe: step 1, image 1 of 1
      • Use your nail or a spudger to pry the back cover off of the device.
      Ask FixBot
    2. HP Stream 8 Battery Replacement: step 2, image 1 of 1
      • Slide your finger around the rest of the back cover, lifting it completely off of the device.
      Ask FixBot
    3. HP Stream 8 Battery Replacement: step 3, image 1 of 1
      • Remove ten Phillips #00 screws from the inside cover.
      Ask FixBot
    4. HP Stream 8 Battery Replacement: step 4, image 1 of 1
      • Pry up the inside cover the same way as in the first step.
      Ask FixBot
    1. HP Stream 8 Battery Replacement, Front-Facing Camera: step 5, image 1 of 1
      Tool used on this step:
      Buy
      • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
      Ask FixBot
    2. HP Stream 8 Battery Replacement: step 6, image 1 of 1
      • Remove the front facing camera with tweezers.
      Ask FixBot
    1. HP Stream 8 Battery Replacement, Rear-Facing Camera: step 7, image 1 of 1
      Buy
      • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
      Ask FixBot
    2. HP Stream 8 Battery Replacement: step 8, image 1 of 1
      • Remove the back facing camera with the tweezers.
      Ask FixBot
    1. HP Stream 8 Battery Replacement, Motherboard: step 9, image 1 of 1
      Buy
      • Carefully remove the battery connector from the system board using the tweezers.
      Ask FixBot
    2. HP Stream 8 Battery Replacement: step 10, image 1 of 1
      • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
      Ask FixBot
    3. HP Stream 8 Battery Replacement: step 11, image 1 of 1
      • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
      Ask FixBot
    4. HP Stream 8 Battery Replacement: step 12, image 1 of 1
      • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
      Ask FixBot
    5. HP Stream 8 Battery Replacement: step 13, image 1 of 1
      • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
      Ask FixBot
    6. HP Stream 8 Battery Replacement: step 14, image 1 of 1
      • Remove the motherboard from the device.
      Ask FixBot
    1. HP Stream 8 Battery Replacement, Battery: step 15, image 1 of 1
      • Remove the 6 PH00 Phillips screws.
      Ask FixBot
    2. HP Stream 8 Battery Replacement: step 16, image 1 of 1
      • The battery can now be removed from the device.
      Ask FixBot
3 other people completed this guide.
Author
with
Nick Miller
669 Reputation
6 Guides authored
Cal Poly, Team 34-14, Maness Spring 2016 Member of Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Members
72 Guides authored
2 Guide Comments
We're I can buy battery for stream 8 tablet 4000mah
Marlon Ultado - Reply Share
Bonjour,
pouvez-vous m'indiquer où je pourrais trouver une batterie compatible ?
Bien cordialement
GAVALDA - Reply Share
Past 24 Hours: 5
Past 7 Days: 26
Past 30 Days: 116
All Time: 5,961
