Up to 20% off select tools
HP Stream 7 Screen Replacement
Views: 5.1K
View statistics:
Past 24 Hours:
Past 7 Days:
20
Past 30 Days:
113
All Time:
5,078
Comments: 7
1 comment on steps, 6 guide comments.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 7 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Since HP Stream 7 is a tablet and has many small parts. Be careful when removing/replacing parts. Do not force anything to avoid breaking device material.
    1. HP Stream 7  Screen Replacement, Battery: step 1, image 1 of 2 HP Stream 7  Screen Replacement, Battery: step 1, image 2 of 2
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      Ask FixBot
    2. HP Stream 7  Screen Replacement: step 2, image 1 of 2 HP Stream 7  Screen Replacement: step 2, image 2 of 2
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      Ask FixBot
    3. HP Stream 7  Screen Replacement: step 3, image 1 of 2 HP Stream 7  Screen Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      Ask FixBot
    1. HP Stream 7  Screen Replacement, Motherboard Replacement: step 4, image 1 of 1
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      Ask FixBot
    2. HP Stream 7  Screen Replacement: step 5, image 1 of 2 HP Stream 7  Screen Replacement: step 5, image 2 of 2
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      Ask FixBot
    3. HP Stream 7  Screen Replacement: step 6, image 1 of 2 HP Stream 7  Screen Replacement: step 6, image 2 of 2
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      Ask FixBot
    1. HP Stream 7  Screen Replacement, Screen Replacement: step 7, image 1 of 1
      • After removing the motherboard, unscrew the four 2.5 mm Phillips 000 screws from the display panel.
      Ask FixBot
    2. HP Stream 7  Screen Replacement: step 8, image 1 of 1
      • Using your spudger, pry the display panel off the front.
      Ask FixBot
    3. HP Stream 7  Screen Replacement: step 9, image 1 of 1
      • The screen should now just come right off. Be sure to catch any broken bits if the screen is damaged.
      Ask FixBot
6 other people completed this guide.
Author
with
Justin Schnorf
252 Reputation
2 Guides authored
Cal Poly, Team 18-5, Forte Fall 2016 Member of Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Members
36 Guides authored
6 Guide Comments
where can i buy new screen????
eibrims - Reply Share
Yeah, I want to know where I can buy a screen for my hp stream 7.
Rider Sd - Reply Share
Where can i buy a new screen for the stream 7 please??
migueajr - Reply Share
Same question but no answer !
Where can anyone find replacement screen online ??
Ahmed Saleh - Reply Share
We're I can buy the replacement screen?
Raymond Borrero - Reply Share
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 113
All Time: 5,078
