Up to 20% off select tools
HP Stream 7 Motherboard Replacement
Views: 2.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
86
All Time:
2,386
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Before beginning, make sure you discharge any static electricity stored in your hands by either touching a metal object (preferably grounded) or using the anti-static wrist strap.
    1. HP Stream 7  Motherboard Replacement, Battery: step 1, image 1 of 2 HP Stream 7  Motherboard Replacement, Battery: step 1, image 2 of 2
      • Make sure the tablet is powered off before beginning.
      • Gently run the plastic opening tool or your fingernails around the tablet to pry the Back Cover from the tablet.
      Ask FixBot
    2. HP Stream 7  Motherboard Replacement: step 2, image 1 of 2 HP Stream 7  Motherboard Replacement: step 2, image 2 of 2
      • Remove the eight 5 mm Phillips 000 screws.
      • Gently run the plastic opening tool around the seam to pry the mid back cover from the tablet.
      Ask FixBot
    3. HP Stream 7  Motherboard Replacement: step 3, image 1 of 2 HP Stream 7  Motherboard Replacement: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, gently pull the battery connector towards the battery to remove it from the System Board.
      • Pull the blue tabs (Not Shown) out from the tablet at an angle to remove the tape underneath the Battery.
      • If you broke both tabs, scrape the tape and Battery off.
      • Scraping off the Battery will damage it. If you are replacing another part, leave the Battery on the display panel.
      Ask FixBot
    1. HP Stream 7  Motherboard Replacement, Motherboard Replacement: step 4, image 1 of 1
      • Disconnect the battery from the motherboard, but leave the battery on the display panel (unless you have already taken it off).
      • Disconnect the motherboard from the rear-facing camera, the front-facing camera, the antenna, the power button board, the screen, and the display panel using your spudger.
      • The cable connected to the display is adhered to the panel, so be careful when removing the cable (like most things here).
      • If you are inexperienced with disconnecting everything, "Recognizing and Disconnecting Cable Connectors" is a helpful ifixit guide.
      Ask FixBot
    2. HP Stream 7  Motherboard Replacement: step 5, image 1 of 2 HP Stream 7  Motherboard Replacement: step 5, image 2 of 2
      • Remove the two 2 mm Phillips 000 screws from the motherboard.
      Ask FixBot
    3. HP Stream 7  Motherboard Replacement: step 6, image 1 of 2 HP Stream 7  Motherboard Replacement: step 6, image 2 of 2
      • Once unscrewed, the motherboard separates from the rest of the device.
      • The speaker is soldered to the motherboard, but it comes off easily.
      • Forced separation may result in a damaged motherboard and/or personal injury.
      Ask FixBot
Author
with
Justin Schnorf
252 Reputation
2 Guides authored
Cal Poly, Team 18-5, Forte Fall 2016 Member of Cal Poly, Team 18-5, Forte Fall 2016
CPSU-FORTE-F16S18G5
4 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 86
All Time: 2,386
