Tools
Introduction
Go to step 1 ↓Is your computer running slowly when you have multiple browser tabs open? It might be time for a RAM upgrade. Follow this guide for the removal and reinstallation of your laptop’s RAM component.
Replacing RAM is a very simple, straight-forward process. However, the laptop's battery must be removed prior to removing the battery, making the entire process moderately difficult.
For this guide, all you need is a plastic opening tool and a Phillips #1 screwdriver head.
Use an opening pick to gently pry up the edge of the rubber foot.
Grab the lifted edge of the foot and gently pull it away.
Repeat for the other rubber foot.
There are spring-loaded metal clips on each side of the RAM stick. Place your fingers on each metal clip and push them to the side.
